Open V-Carve Pro 9 files in Aspire 8.5
Postby DHDeirick » Tue Aug 01, 2017 12:40 am
While still in the "checking things out" mode while trying to decide about getting a CNC machine, I have downloaded the Trial version of V-Carve Pro and Aspire. Additionally, I have joined a local maker group that has Aspire 8.5 for use with their CNC machine so I can get some experience with the possibilities of of CNC machining. While I can construct some files using the Demo version of V-carve pro, I cannot save tool paths. While I have no problem with that, I cannot open files created in V-Cave Pro 9 or Aspire 9 into Aspire 8.5 at the Maker Space to cut my projects. At least not with my current knowledge of the software.
Is there a way to save the design part of the files so that they can be imported in to Aspire 8.5?
Dave D.
DHDeirick
Model of CNC Machine: CNC Shark
Re: Open V-Carve Pro 9 files in Aspire 8.5
Postby highpockets » Tue Aug 01, 2017 12:51 am
V9 is not backwardly compatible with any previous version.
You can save all your toolpath files with the Post Processor for the clubs machine, copy them to a thumb drive and load them to the machine's computer.
Postby 4DThinker » Tue Aug 01, 2017 2:01 am
Files created with the trial version will not open on any other PC. They will work on the same PC as the trial if you install the licensed version there.
4DThinker
Postby martin54 » Tue Aug 01, 2017 2:22 am
highpockets wrote:V9 is not backwardly compatible with any previous version.
You can't save toolpaths using a trial version John but even if you could as 4DThinker has pointed out you need to have the licenced software on the same computer as the trial version.
Postby highpockets » Tue Aug 01, 2017 2:28 am
Whoops!! :oops: :oops: :oops: Keep forgetting that.
Postby DHDeirick » Tue Aug 01, 2017 3:11 am
I understand that I can’t save toolpaths. I have no problem with that. I just wanted to move the vector definitions from one place to another so I could then generate and save the toolpaths in the licensed version that the Maker group has.
Guess it just isn’t possible. I have to re-create the entire project. Well, at least I will get some practice with it until I get my CNC machine, which includes Vcarve.
Dave
DHDeirick
Postby ger21 » Tue Aug 01, 2017 1:23 pm
As mentioned, that's not allowed, regardless of version.
Gerry
ger21
Return to Aspire - General
