Latest Guitar neck profiles cut and fretboard inlays
Postby angelkarla » Sun Jul 30, 2017 10:55 am
Been a while thought i must post the latest guitar neck profiles cut using aspire two sided maching.
I used 3/4 inch thick maple and wenge the first side cutting slot for truss rod, then infil over the top again and machining levell
Turned over then machined neck profile and tuner holes.
A 1/4 inch thick fretboard glues on neck front inays are mother of pearl white outside black inside cut using a 1/32 cutter.
neck machining
If all else fails read the instructions
angelkarla
Model of CNC Machine: home made
Re: Latest Guitar neck profiles cut and fretboard inlays
Postby angelkarla » Sun Jul 30, 2017 11:00 am
Inlays
angelkarla
Postby angelkarla » Sun Jul 30, 2017 11:01 am
Inlays
angelkarla
Postby mikeacg » Sun Jul 30, 2017 1:05 pm
Love the inlays!
Still haven't tried cutting a neck but my bass player has some stock glued up to try so it won't be long...
Thanks for sharing!
mikeacg
Postby angelkarla » Mon Jul 31, 2017 8:22 am
Mike by cutting into strips and turning 90 degrees and glueing then re planing this gets the grain of the wood the best way to take the strain from the strings and stop the neck bending excessively (you probably know this any way)
angelkarla
Postby dvaskie127 » Tue Aug 29, 2017 8:38 pm
Looks awesome what program did you use to model them? I've been trying to model a neck in rhino and just can't get it right. I added a couple of files of necks I've done.
24 B Fret Neck.zip
(37.72 KiB) Downloaded 83 times
NeckContour.dxf
(379.51 KiB) Downloaded 90 times
dvaskie127
Postby sylvan356 » Tue Aug 29, 2017 8:56 pm
Nice job!
sylvan356
Model of CNC Machine: CAMaster Stinger 1 w/Rotary, Aspire 9
Postby PiedmontSlim » Mon Sep 11, 2017 5:55 pm
Thanks for posting. Necks are my next project. As soon as I figure out what's wrong with the model for my tele body
Eric
PiedmontSlim
Model of CNC Machine: Legacy ARTY
Postby sseale » Mon Sep 11, 2017 7:20 pm
Nice work. Are the thin fret slots cnc machined as well? If so where do you get your end mills for that?
Scott
sseale
Model of CNC Machine: Probotix Nebula
Return to Aspire - General
Users browsing this forum: Ivanho1 and 29 guests
