Follow sloped taper
Follow sloped taper
Postby Keith Larrett » Sat Jul 29, 2017 11:33 am
I need to make a key for a range hood. I have the key shaped used the molding toolpath and the profile toolpath. What I need to do is run a cove bit down the length of the long sloped, tapered edge then along the bottom of the key and then back up the other long sloped, tapered edge.
Any ideas as to how I can accomplish this would be great?
I know I can do this at my router table easily enough, I would like to know if/how I would do it on the CNC.
I have attached the file I created in Aspire 8.5
Thanks.
Key.crv3d
(175.5 KiB) Downloaded 36 times
https://www.syzygywoodworks.com
https://www.facebook.com/SyzygyWoodworks
Keith Larrett
Model of CNC Machine: ShopBot
Re: Follow sloped taper
Postby ger21 » Sat Jul 29, 2017 11:47 am
Offset a perimeter vector inwards about .001, and project a profile toolpath onto the model, using an appropriate sized ballnose bit.
Gerry
ger21
Postby Keith Larrett » Sat Jul 29, 2017 12:05 pm
Thanks for the reply. I tried your suggestion but it didn't work. It just cut at the same level, it didn't follow the taper down the slope.
Maybe because it is not a 3D model?
Keith Larrett
Postby Keith Larrett » Sat Jul 29, 2017 12:34 pm
Ok. I'm starting to get somewhere :)
Using a combination of fluting tool path and profile on the line cut. Just need to figure out my start depth and cut depth.
Keith Larrett
Postby ger21 » Sat Jul 29, 2017 12:50 pm
Sorry, I thought is was a model.
Gerry
ger21
Postby eph210 » Sun Jul 30, 2017 2:48 am
After you have created the preview of the key using the molding toolpath, go to the modeling drop down menu. At the bottom is create component from preview. Click on that and then use that component as the model for Gerry's suggestion.
Euan
eph210
Model of CNC Machine: Stinger 1 and Mabel, both with 4 axis
Postby Keith Larrett » Mon Jul 31, 2017 2:44 am
Thank you! I didn't know that could be done. That is a more efficient way of making the cove cuts.
Keith Larrett
Postby 4DThinker » Mon Jul 31, 2017 3:02 am
You can do the cove around the ramp with one fluting toolpath. No component/model needed. Your side view has all the info you need, and I've added dimensions created by Aspire to show you the where I got the depth of cut and the length of ramp before it goes flat.
4D
Key4D.crv3d
(252.5 KiB) Downloaded 33 times
4DThinker
Postby Keith Larrett » Tue Aug 01, 2017 2:21 am
Unfortunatly I was not able to open your file. I have Aspire 8.5
I would have liked to have seen how you did the fluting in one pass.
I cut the key out. I was pleased with how it came out.
Keith Larrett
Postby 4DThinker » Tue Aug 01, 2017 3:02 am
8.5 version attached. May differ a bit from the 9.0 version, but the fluting toolpath would be the same.
Key4D8.5.crv3d
(296 KiB) Downloaded 47 times
4DThinker
Postby Keith Larrett » Tue Aug 01, 2017 9:52 am
Thanks for converting the file to 8.5
I see what you did and have a better understanding of the fluting path now. My only question is how you arrived at the start depth of 0.1875 Where you cutting the flute to a depth of 1/8"? So the start depth would have been that 1/8" plus the 1/16" that had been removed from the top of the blank, 0.125 + 0.0625 = 0.1875?
Appreciate your help!
Keith Larrett
Postby 4DThinker » Tue Aug 01, 2017 11:31 am
Keith Larrett wrote:I see what you did and have a better understanding of the fluting path now. My only question is how you arrived at the start depth of 0.1875 Where you cutting the flute to a depth of 1/8"? So the start depth would have been that 1/8" plus the 1/16" that had been removed from the top of the blank, 0.125 + 0.0625 = 0.1875? Appreciate your help!
Your moulding tool path was set to cut 1/16" under the top of the board. To that I added 1/2 the diameter of the ball nose bit I used for the fluting cove. I started out using a 1/4" ball nose bit, but when I redid it all for 8.5 I may have selected a 3/8" bit without going back and updating my cut depth. To get a little more depth using the 3/8" bit the cut depth should have been 0.0625 + 3/16.
4D
4DThinker
Postby Keith Larrett » Tue Aug 08, 2017 2:35 am
This is the finished project. The key, lower rail, center stile and two panels were all cut using Aspire.
I had to cut the key twice. When I applied the stain to the first key I neglected to take into account the sloped face of the key was essentially all end grain, so it absorbed to much stain and was very dark. Before applying the stain on the second key I applied a couple coats of diluted sanding sealer.
Thank you again for the help.
Keith Larrett
Postby highpockets » Tue Aug 08, 2017 2:42 am
Beautiful work!
Postby mtylerfl » Tue Aug 08, 2017 2:58 am
Wow! That came out great!
Next
Return to Aspire - General
Users browsing this forum: No registered users and 16 guests
