Circles/arcs problem Masterwood P416
Postby tusong200 » Fri Jul 28, 2017 3:57 pm
Thanks in advance for any help.
When using the draw circle/ellipse tool to create circles everything seems fine during the toolpath preview. But when executing the toolpath on the Masterwood P416 (using the supplied postprocessor "M-wood P416 ATC") the arcs are interpreted incorrectly. Instead of a circle I get a 4-point star with curved inward sides. The four quadrant arcs of the circle are flipped inward.
However, if I create the circles in CorelDraw, export them as DXF, and import them into Aspire then they machine properly. This has been my workaround in the past but it has become a hassle.
Any thoughts????
Another issue is that the M-wood P416 ATC post processor seems to work 99% but it never establishes the spindle speed at G172. I always have to go into the code and add "S12" at the first G172.
Any enlightened sous out there??? Thanks!
tusong200
Model of CNC Machine: Masterwood Project 416
Re: Circles/arcs problem Masterwood P416
Postby 4DThinker » Fri Jul 28, 2017 4:07 pm
Your controller/post processor may not be able to interpret a g-code arc command properly. Some post processors have "arc" in their name indicating that they can deal with true arcs. Imported arcs are often just a group of short polyline vectors that look like an arc which is why they cut OK. You can tell the difference by using the (N)ode command to highlight what your Aspire drawn vs imported arcs are actually composed of.
How to help you I don't know. I'm not exactly sure how drawn arcs are usually dealt with in the post processors.
4DThinker
Postby mohamed » Fri Jul 28, 2017 4:33 pm
Could you contact support (support@vectric.com) about this. It looks like the arc is being interpreted in a reverse direction (clockwise rather anticlockwise, or vice versa). It could be an issue with the postprocessor, so it's worth investigating just to make sure.
Mohamed
Mohamed
mohamed
Vectric Staff
Postby tusong200 » Fri Jul 28, 2017 10:13 pm
The post processor is actually named "M-wood p416 ATC arc". I'm not sure if I got it with Aspire or found it somewhere else. I've been using it for several years and just don't remember the source. Maybe someone can tell me if it is included with 8.5 or the newest version.
tusong200
Postby mohamed » Wed Aug 02, 2017 10:22 am
It's included in both versions. One thing to check is if that post-processor file is in My_PosP, it won't have been updated by subsequent patches, so make sure it's in sync with the one in PostP. (Folders I'm referring to you can go from 'File' -> 'Open Application Data Folder').
Mohamed
mohamed
Vectric Staff
Return to Aspire - General
