Creating a vertical tool path
Postby doublem » Fri Jul 28, 2017 4:19 am
I am trying to get my spindle to cut a semi circle vertically. Imagine cutting a slot for a cd disk to fit snugly >
Ant ideas out there?
doublem
Model of CNC Machine: ross cnc
Re: Creating a vertical tool path
Postby highpockets » Fri Jul 28, 2017 4:30 am
Something like this?
Try the "Fluting" toolpath.
Postby rsetina » Fri Jul 28, 2017 5:34 am
I'm curious about how deep you want the slot to be cut? You'd have to cut pretty deep for a CD and I'd be interested in the tool you'd use to cut the deep.
Rick
Shark HD 2.0
rsetina
Model of CNC Machine: Shark HD 2.0
Postby 4DThinker » Fri Jul 28, 2017 5:55 am
I believe the fluting toolpath cuts more of an elliptical path than a circular arc. You can use the moulding toolpath with half circle (or smaller fraction of a circle) and a very short guide rail to make a true circular slot. Be sure and use the Larger area clearance option if the slot is very deep.
4DThinker
Postby doublem » Fri Jul 28, 2017 11:08 pm
I HAD BETTER COME CLEAN :D
I am trying to add a hot wire to my gantry to make aeroplane wings. I may have to go to other software but most of it is for 4 axis foam cutting machines.
I intend to manipulate the wire assembly to create tapers and such like. So I was looking for a short cut with Vectric software. Hears hoping,
doublem
Postby Rcnewcomb » Fri Jul 28, 2017 11:15 pm
Vectric doesn't support moving 4 axies at once
Postby doublem » Sat Jul 29, 2017 3:29 am
I am aware of that.
My plan is to use a bar with a how wire suspended to move along the y axis with the bar across the table and the x moving fwd in and arc . Only using the 3 axis
doublem
Postby rsetina » Sat Jul 29, 2017 8:47 am
I've seen foam airplane wings being cut out with a wire before, but the wire is as long as the wing itself and very thin so not much current is needed to make the wire hot enough to cut the foam. This was when I was a young teenager so I'm remembering the process 35 years ago. The wings where for gliders and where tapered thinner at the tips.
I'm trying to see your setup from your description of the bar and wire. I assume there will be two bars at either end of the X axis with a wire going between them. Are the wings the same thickness from end to end? I can see where you are going with this. It's an interesting experiment. I hope you can make it work.
Rick
Shark HD 2.0
rsetina
Postby IslaWW » Sat Jul 29, 2017 1:09 pm
doublem...
Assuming that you machine does not support arcs in the G18/19 planes and your wing is not an arc there is a way.
Draw the profile to be cut in the XY plane. Make sure that it has no arcs or arc segments. Toolpath. In the gcode file, swap the X or Y for the Z to change your profile to a vertical plane
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby ohiolyons » Sat Jul 29, 2017 9:30 pm
OK now I put this on the edge so you could see the cut. I personally don't have the tooling to cut this. The cut in the photo is half a CD, if this is what you wanted to do I can include the file and a further explanation.
CNC in Kettering, Ohio
ohiolyons
Model of CNC Machine: Laguna IQ HHC, 3HP
Postby mtylerfl » Sat Jul 29, 2017 10:41 pm
doublem wrote:I HAD BETTER COME CLEAN :D
I've manually cut a lot of foam wings for my scratch-built RC models - but that has been over 20 years ago. I made my own hot wire cutter using aluminum square tubing, springs, wires, screws, etc. and a homemade footswitch with a transformer from Radio Shack providing the voltage to the wire.
Conventional "old-school" was make plywood templates (polished, smooth edges) for the root chord and tip, affix them to each end of a foam block and draw the wire through the foam whilst resting the wire on the two end templates and regulating the heat of the wire (in real-time while pulling the wire) using the footswitch on/off.
If you've done this yourself, you know if it's a tapered and/or swept wing, it's a bit tricky to get the "feel" for drawing the wire over the templates (and through the foam) at the right speed. Too slow - the wire melts divots/lines in the foam...too fast, you introduce distortion into the wing contour. You also have to vary the speed at an angle (moving a little faster over the longer root chord template) so the wire exits the foam in a straight line at exactly the same time from both templates at the trailing edge of the wing.
I've never seen a commercial CNC foam cutter in-person. I would certainly like to see one set up specifically for cutting wings and learn how they work, how they get the wire temp just right, and how the angled speed compensation is made for tapered/swept wings between the root chord and tip ends.
I'm very interested in your plans to rig your CNC for cutting foam wings using 3 axes. Rooting for you!
Postby LittleGreyMan » Sun Jul 30, 2017 1:20 pm
Best regards
LGM
W7 - Aspire 8.517
LittleGreyMan
Model of CNC Machine: 3 axis Charlyrobot & Mecanumeric
Postby doublem » Mon Jul 31, 2017 2:33 am
Ooops . Got a threat warning trying to download jedcust.
Thanks for everyone interest and input. Really want to make it happen since I started model flying again.
Cheers for now
doublem
Postby mtylerfl » Mon Jul 31, 2017 2:52 am
Well, you got me digging in old photo albums looking for my old RC aircraft photos. Could only find a few - probably the majority are in the attic in a box somewhere.
Judging by how I look in the photo, it was over 30 years ago I got into building. All of them are equipped with foam wings I cut myself. The space shuttle delta wing was cut in six sections - that was a bear to figure out!
Not a single one of the over 20 models I built had any horizontal stabilizer! Only wings and rudder. Very stable - almost impossible to stall. (Except the shuttle - it flew like a brick - too heavy and underpowered. I donated it to a local children's library to hang from the ceiling after I was done playing with it!)
Postby 4DThinker » Mon Jul 31, 2017 3:06 am
Nicely done, mtylerfl. I remember the day when motors burned gas rather than electricity, and there was a Space Shuttle making regular trips to the space station. ;)
4DThinker
Next
Return to Aspire - General
Users browsing this forum: kilrabit and 32 guests
