can anyone help coverting to dfx
Xxray
Post by Xxray »
Kinda rush job, going to do it for material cost only considering the recipients here.
2D probably edge lit, no intention to go 3D. Put a few hours into it and still coming short ,,, Text am not worried about, but details like the eagle/shields are coming up pretty badly.
If any of you wizards [which I should be after 5+ years] feel like gibing it a go, I'd be much obliged.
Re: can anyone help coverting to dfx
Post by highpockets »
Doug, I'd be willing to help, but I'm just not fast enough at creating vectors yet.
Have you tried to contact the organization and see if they have a copy of the original art work. I'd bet it was done in Illustrator or other vector based app.
What is your deadline?
Doug,
Decided to give it a try. Haven't fixed some of the open vectors and haven't built the center shield. Thought I'd see if I was going in the right direction before continuing.
FSEA.crv
(237.5 KiB) Downloaded 161 times
Phil
Post by Phil »
As for the eagle drawing I googled for "Eagle Drawing" and came up with this https://www.google.com/search?q=eagle&b ... le+drawing You may find a suitable image. I would try googling for any of the difficult images.
Hope this is helpful.
Phil
dwilli9013
Post by dwilli9013 »
Id say that's a pretty darn good first run at it. :lol: :lol: :lol:
D-Dub
Dwayne
Dwilli
Thanks Dwayne.
Doug,
Couldn't stand it I took a shot at the shield also. Eagle sucks, but so did their's LOL.
FSEA.crv
(248 KiB) Downloaded 142 times
dwilli9013
highpockets wrote:Thanks Dwayne.
Doug,
FSEA.crv
HP nice job. Only thing I would change is to elongate the beak a work it over a bit. Rest looks superb.
D-Dub
Dwayne
Dwilli
Thanks Dwayne,
Finished the eagle at 4am this morning, was getting a bit punchy, had to hit the sack for a bit. :D :D :D
Think you're right looking at the eagle again now.
Dwayne,
I reworked the eagle a little bit. Still no work of art but a bit better.
FSEA.crv
(249.5 KiB) Downloaded 148 times
dwilli9013
highpockets wrote:Dwayne,
The attachment FSEA.crv is no longer available
HP much better. I actually touched the eye just a bit. :lol: :lol: He just had that kind of death stare. XxRay should like that it will look tight on an edgelit. :lol: :lol:
FSEA.crv
(249.5 KiB) Downloaded 151 times
D-Dub
Dwayne
Dwilli
Dwayne,
Nice touch. I'm not too sure how much all this fiddling with the eagle is going to help though. Unless Doug plans on making a very big edge lit sign the eagle is going to be just a smudge :D :D :D
dwilli9013
True I was working on a 12 x 12 piece lastnight when I crashed my drag bit. Was a sweet piece too :shock:
D-Dub
Dwayne
Dwilli
Xxray
Post by Xxray »
Thanks John and all, won't have the time to mess with it until later but I'll post back ... I know the eagle is somewhat of a mess, size will probably be in the 12x12 area, am confident drag bit can pick up every bit of detail there is [which can be both good and bad]
Did this mayan edgelit some time back, drag bits are capable of very fine detail if the vectors are in order
Very pretty piece Doug. I have edge lit signs on my list of things to get Round-To-It.
Xxray
Post by Xxray »
Design a little more complex than I had thought, this is what I came up with.
Will post back if/when I make it, looks like a go at this point - Any criticisms welcome.
