2.5 D Machining
- Model of CNC Machine: Heiz High Z Machine German manufacture
2.5 D Machining
Hi, I wish to machine a small square component with straight cut (90degree angles) on three sides..... but the fourth side to be machined at a slight angle.
Is there an easy way to do this?
Soapy
Soapy
Re: 2.5 D Machining
Depends if you have a bit that matches the angle. If not you would have to create the fourth side using a moulding toolpath.
Re: 2.5 D Machining
Thanks Adrian,
I am not quite sure (bit thick) what you mean by the moulded toolpath
Soapy
Soapy
Re: 2.5 D Machining
Moulding tool path or the fluting tool path for the slight angle.
- 1SlopeSideF.crv3d
- (37 KiB) Downloaded 105 times
- 1SlopeSideM.crv3d
- (39.5 KiB) Downloaded 117 times
Re: 2.5 D Machining
Thanks Adrian,
Usually I cut out the pieces with a straight cutter then, as a second operation taper one of the sides ...holding the piece in a jig
I thought it would be neat to cut out the piece at one go but have never figured how to do it
Soapy
Soapy
Re: 2.5 D Machining
Adrian sorry could not open the file.... I am using Aspire 8.5
Re: 2.5 D Machining
Try those files again. I replaced them with files made in 8.5.
The Moulding tool path is on the tool path menu (right side) and created files named SweptProfile unless you've given them a different name. I needs a guide line and profile line to extrude down that guide line.
4D
4D
Re: 2.5 D Machining
Thanks Adrian,
That, in principal is what I need to do.
Re: 2.5 D Machining
That's not me helping you out.
Re: 2.5 D Machining
Sorry still struggling a bit of with this
What is the purpose of boundary offset in the moulding toolpath ?
Is it similar to normal offset ?
Re: 2.5 D Machining
Can't explain it better than the Help does.
Boundary Offset
This option can be used to force the toolpath to cut past the edge of the part that is parallel to the drive curve vector. By default the center of the tool will go to the edge of the ends of the selected profile vector as its extruded along the drive rail. It may be desirable to extend this distance to either force the tool down the edge of the profile shape with vertical or steep edges or to ensure the toolpath has gone far enough past the edge to cleanly cutout the final shape with a profile toolpath. The value entered for the Boundary Offset will force the tool past the ends by the specified amount. As such if you want to ensure a vertical or very steep edge at your profile ends is machined you will need to specify a value which is at least the radius of your tool plus a small additional amount (say an additional 10% of the radius). For example if you are using a 0.25 inch (6mm) diameter ball-nose tool for the finish cut then you would specify a minimum of 0.15 inch or 3.6mm (= tool radius + 10%) to ensure the tool would be forced down the edges of your shape. If you wanted to ensure the roughing had also been able to machine these areas then the value should be based on your Larger Area Clearance Tool size instead.
Re: 2.5 D Machining
I have seen in this forum screen shots of the 3D view of an object made in Vectric.
How is this achieved
Re: 2.5 D Machining
Thanks Adrian for your explanation .... great help
- Model of CNC Machine: Shark HD 2.0
Re: 2.5 D Machining
That's done in the preview toolpath. After simulating the toolpath you get an image of what the part looks like. On that same screen you can save preview image just above the close button. Save it to a location and you can share it from there.Soapyjoe wrote:I have seen in this forum screen shots of the 3D view of an object made in Vectric.
Rick
Shark HD 2.0
Shark HD 2.0
Re: 2.5 D Machining
Thanks Rick
