Adding to previous model?
Postby oldlogtrucker » Fri Jul 21, 2017 6:12 pm
I have a horseshoe model that is done. I want to add a connecting bar across the top with aspire. I think I need to use the modeling tool but I cannot seem to get my model 2 inches thick. Getting the length seems to work but does not want to get raised to height. Any suggestions from you seasoned modelers?
Thanks Kathy
Camaster StingerII - FTC, Vac Table - Aspire
Embroidery - WingsXP
oldlogtrucker
Model of CNC Machine: Cam Master StingerII
Re: ADDING TO PREVIOUS MODEL?
Postby Leo » Fri Jul 21, 2017 6:36 pm
Kathy,
Can you post pictures? What file format is the model that you already have?
Depending on the model format you should be able to add and get all the sizes you want.
If you have an STL maybe not, but I am not all that skilled yet. The real modeling people may have more information to add.
Either way, we will need a little more info.
www.leosworkshop.com
Leo
Postby highpockets » Fri Jul 21, 2017 7:45 pm
Something like this?
Postby dealguy11 » Fri Jul 21, 2017 9:57 pm
I'm glad Highpockets made a model because that's what I would have guessed, too. If you're just trying to put a bar across the top and your horseshoe model is already at the right thickness, then the modeling tool is probably not the right tool for the job. Better to create a new component with the shape and height you want, then combine the two with a combine mode of "Merge".
Steve Godding
dealguy11
Postby oldlogtrucker » Sat Jul 22, 2017 1:25 am
Thank You I will try that. You guys are the best.
Kathy
oldlogtrucker
Postby oldlogtrucker » Sat Jul 22, 2017 1:39 am
So High Pockets, how did you manufacture the model of your board?
Thanks Kathy
oldlogtrucker
Postby oldlogtrucker » Sat Jul 22, 2017 1:46 am
I am trying to make a frame from the horseshoe.
Thanks Kathy
oldlogtrucker
Postby highpockets » Sat Jul 22, 2017 2:20 am
oldlogtrucker wrote:So High Pockets, how did you manufacture the model of your board?
Thanks Kathy
Kathy,
I just drew a rectangle over the horseshoe then used "create a shape from vector outlines" on the Modeling tab. I clicked the "Flat Profile" under "Shape Profile".
Postby highpockets » Sat Jul 22, 2017 2:29 am
oldlogtrucker wrote:I am trying to make a frame from the horseshoe.
Thanks Kathy
Postby highpockets » Sat Jul 22, 2017 2:31 am
Having a little fun with the new double sided feature and Kathy's project.
Postby oldlogtrucker » Sat Jul 22, 2017 3:09 am
Yes that is the general idea of what I am shooting for.
Kathy
oldlogtrucker
Postby highpockets » Sat Jul 22, 2017 3:31 am
Here you go... Thank Leo for the horseshoe.
Horseshoe2.crv3d
(807.5 KiB) Downloaded 47 times
Postby highpockets » Sat Jul 22, 2017 3:29 pm
Well Kathy just made me aware of something I think is going to be an issue.
Aspire v8 can't read .crv3d files created in v9!!! And I couldn't figure out how to save to v8. I recreated the horseshoe in v8 and it's too big to upload!!!!
Am I missing something here?
Postby highpockets » Sat Jul 22, 2017 3:38 pm
OK, figured out the size issue. I had the Model Resolution on Very High.....
Horseshoe with bar v8x.crv3d
(974 KiB) Downloaded 34 times
Re: Adding to previous model?
Postby oldlogtrucker » Sat Jul 22, 2017 5:53 pm
stampede2.crv3d
(591.5 KiB) Downloaded 57 times
Okey guys, This is what I wound up with, can you tell me what I may have done differently than you did? :shock:
thanks Kathy
oldlogtrucker
Next
Return to Aspire - General
Users browsing this forum: ctbjdm, Google [Bot] and 32 guests
