Cutting Chloroplast
Cutting Chloroplast
Postby DEdwards » Fri Jul 21, 2017 3:29 pm
We are cutting out arrows from chloroplast, and this is the first time we are using the router for something like this. I have been doing some research and so far I have stumbled across very little.
My question is, what would be the best bit to use for routing such a thing piece of material? Along with that what type of speeds and feeds would you try to use on something like this.
I am sorry if this is a dumb question but I am stumped. Thank you for any information.
Devin - BSG
DEdwards
Model of CNC Machine: I dont know
Re: Cutting Chloroplast
Postby IslaWW » Fri Jul 21, 2017 4:36 pm
Use single O flutes designed for soft plastic. you will have to play with rpm and feedrates to get rid of fuzzies
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby Adrian » Fri Jul 21, 2017 4:40 pm
Another way is to use a drag knife. Depends if you're doing enough to make the investment in one worthwhile and what thickness of coroplast you're using.
http://donektools.com/cnc-knife-cutting ... ial-video/
Postby John Murphy » Fri Jul 21, 2017 8:28 pm
I've always had issues with fuzzies when cutting coroplast. I've tried straight flute "o" bits and down-shear "o" bits, but I can never seam to get rid of the "fuzzies" problem.
Gary, what kind of speed and feeds are you using to overcome this issue?
John Murphy
Model of CNC Machine: AXYZ 5010
Postby IslaWW » Fri Jul 21, 2017 8:36 pm
John...
I'm not. But I can remember helping out a sign shop on a service call a few years back to get his dialed in.
Just like any other material, start at 50, plan on going up to 300. Rpm between 8000 and 18000. There will be a combo that works best
Gary Campbell
IslaWW
Return to Aspire - General
Users browsing this forum: No registered users and 31 guests
