Using Aspire
Using Aspire
Postby Kutton » Fri Jul 14, 2017 1:36 am
Why when I try to cut 3D object feom clip art the machining comes out flat with no difinition showing. I used the roughing and finish portion is software. In preview everything looks great. When I go to machining in Mach3 it come out flat.
Kutton
Model of CNC Machine: Grbl
Re: Using Aspire
Postby Adrian » Fri Jul 14, 2017 8:19 am
Sounds like your Z movements aren't happening. Are you using the correct post processor for your control software/machine? Is it properly calibrated? How are you setting the Z zero?
Basically a lot more information is needed to be able to work out what is going on.
Return to Aspire - General
Users browsing this forum: Google [Bot] and 25 guests
