Need help to create a model
Hello, I need help on creating a model. Does anybody here does this? I need it in grayscale if possible, STL is fine as well. Can anyone turn the attached file into a similar model. Not the same, obviously. I only attached it to show what i want done. I have been looking for a nativity scene but could not find anywhere similar to this in STL or Grayscale. Thank you
- Mike-S
Re: Need help to create a model
If you can get that file without the watermarks, Aspire can make the model for you.
Great thanks! I will go to 123RF. Thank you. By the way on Aspire, is it the 'sculpt' i have to go to on the modelling tab? Thank you again
- Mike-S
You can use the "Sculpt" to change a model.
I just took you pic and created a component from it using "Subtract" to get the dark areas (camels, etc.) to come forward rather than recess into the material. Also applied 20% smoothing to ease the sharp edges.
Sculpt is used to tweak an existing model, not create it.
