Lines parallel to 2 vectors
Re: Lines parallel to 2 vectors
Post by mtylerfl »
FixitMike wrote:And some more fine tuning. I keep finding out more about how the distort tool works.
New method:
Draw 5 equally spaced horizontal parallel lines. (It doesn't seem to matter where you put them.)
Use the Distort Object tool, Between Two Curves,selecting the parallel lines and then the original curves.
Click the Bake Distortion box. Or close the Distort Objects window, right click on a highlighted vector, and Convert to Curves.
Delete the duplicates of the original 2 curves.
Done.
With thanks to mtylerfl
Thank you. That's perfect, FixitMike. Easy procedure and easy to follow instruction.
Excellent explanation and mini-tutorial. That will be very helpful to others, I'm sure.
