Two rail sweep query
Hourigan82
Model of CNC Machine: Impact Storm
Post by Hourigan82 »
Hi everyone, I have been trying to make a simple curved marble track with a 3mm fall, and I'm getting a lot of noise on the outside of the track. I'll clarify.
I have drawn a circle and cut a quadrant out, leaving me with 3/4 of a circle for my drive rails. I then drew the two curves for the profile, and created the profile using two rail sweep.
What I'm finding though, is the grey scale representation of the model is quite pixelly (real word?) around the inner and outer curvature of the shape. When I calculate the 3d finish tool path, it is picking up all these pixels and generating them as tool movements, leaving me with an almost cratered finish around the outer and inner tracks. I have tried increasing modelling resolution on the set up screen, but it doesn't seem to have any affect.
Any ideas?
Re: Two rail sweep query
Post by mtylerfl »
What is your job resolution setting? Is your material size only as large as it absolutely needs to be? Did you place a Zero Plane on your job layout so the swept shape has a reference to make the recessed marble track cleanly?
IslaWW
Post by IslaWW »
You may be best served using the molding and/or fluting toolpath the create this type of shape. Your project is much more geometrical than organic. 3D is more suited to shapes that cannot be defined by math.
GCnC Control
Post by Rcnewcomb »
Adding a zero plane may solve the problem, but Gary's suggestion about a molding or fluting toolpath is probably a better solution for this project.
Post by mtylerfl »
A 2D approach and/or Gary's molding toolpath suggestion is way more efficient (that's what I would have done for a simple project such as the marble tracks).
Hopefully, the OP has also received some clues as to why he has the pixelation problem for the approach he took and asked about.
Hourigan82
Thanks all, I eventually realised a fluted toolpath for this simple shape would probably do the job, but I'm still curious as to why I was having this problem. I will have to re-watch the tutorials for the zero plane, getting my cad packages mixed up and can't remember where it is in Aspire.
Cheers all.
Hourigan82 wrote:Thanks all, I eventually realised a fluted toolpath for this simple shape would probably do the job, but I'm still curious as to why I was having this problem. I will have to re-watch the tutorials for the zero plane, getting my cad packages mixed up and can't remember where it is in Aspire.
Cheers all.
You didn't answer Michaels first post about job size & modelling resolution, this quick tips video will explain some of it for you.
http://support.vectric.com/tips-and-tri ... ideo_id=10
Add Zero plane can be found under the modelling tab about half way down :lol:
