converter file new version
can somebody tell, how I can convert a file from a new version of Aspire to a file for a old version of Aspire
Re: converter file new version
Software versions aren't backward compatible so you can't, you could break the file up though & save the various parts which could be imported into a new job on the older version, you can save 3D models as .stl files or 3dclip files although don't know if the 3dclip flies would import into an older version of the software. Vectors can be exported as well
thanks, so i must made again de toolpad in the new version
- Model of CNC Machine: Touch Probe
Vector export has helped me quite a bit even if software isn't backwards compatible
