USCutter SC Series Vinyl Cutter
- vfauto
- Model of CNC Machine: Legacy Artsian 72"
Is it possible to use Aspire in conjunction with USCutter SC Series Vinyl Cutter. Not sure if it would actually control it with a PP or just design and import into their software which is Sure-Cuts-Alot.
Thank You
Frank
Frank
Re: USCutter SC Series Vinyl Cutter
Depends on how it's driven. The vinyl cutter I use I've never found a way of doing it directly as there just isn't enough info available but I do design in Aspire and then export the vectors as EPS which load directly into the proprietary vinyl cutter software.
If I was using it every day I would try to make it more automated but generally it only gets used once every couple of weeks.
