Breaking down components in clipart
- Model of CNC Machine: CRP 48 X 96Pro
Using Aspire 8.5 Can I not break down the grapes and leafs in the clip art to where the grapes are separate / do as I want as I see from a old tutorial from version 3
- Leo
Re: Breaking down components in clipart
Are you trying to draw vector boundaries around parts of the model to create separate machining areas? Aspire V8.5 is certainly able to do that.
I am not really sure what you are trying to do?
- Turtle49
Yes, You can draw vectors and split the component apart into separate components so that they can be rearranged as needed.
Tim Hornshaw
www.HornshawWoodWorks.com
- Turtle49
Hope this helps,
then you have a separate component.
Tim Hornshaw
I know about clearing inside and outside a vector and LOVE ASPIRE... But I was wanting to ( More easily, get the grapes as individual balls? or all of it by tracing or some other function I am not aware of...) Software is so powerful you guys know and there's always a better way.
I REALLY APPRECIATE ALL OF YOUR INPUTS ON THIS MATTER, Brian
- Mike-S
There is a third tool that does what you want.I know about clearing inside and outside a vector
Brian, draw a vector around what you want to separate and use the "Split the selected component using a vector". That's what the other posts were pointing you to. It's not the clear inside/out function, I'm not sure where you got that from.
Once again thanks !!! I Have never used that tool "Split" I am going to try it right after I get this reply finished. I just love Aspire I am addicted to it and carving is the only cure. I was wondering about how I can split the individual grapes also??? There was a old aspire tutorial on youtube where they did just that. Split eh Okay Thank you all this Forum is Great !!!
- Model of CNC Machine: EZ-Router
If you have Aspire, then why do you want to split individual grapes? Why not create your own?AmericanCNC&Artworks wrote:I was wondering about how I can split the individual grapes also???
There is a video tutorial named “Grape Bunch” that was released during 2008 where the process of creating the grape bunch is explained step by step.
Here are some “screen shots” from the video that might be helpful.
