Greetings. I'm using Aspire to machine the tooling part for a vacuformed tray that is similar to one that you would see inside of a chocolates box. I have several pocket toolpaths made to create the cavities, but since the end product will be a buck for vacuformed plastic, I need to add a 15% angle (or draft) to all my vertical walls of the pocket. I see that Add Draft is an option in the 3D component area of the program, but I haven't found a quick and easy way to add draft on all these pocket toolpaths in the traditional milling area.
If that's not possible, is there a way to take the "rendered" preview of what the CNC would machine with my straight pockets and then bring that in as a complete 3d component, then add the drafts inside that part of the program?
I've managed to get one made, but as I was afraid would happen, the mold tool is stuck inside the plastic because of the tight fit between the part and the tool.
I've attached pictures of the first go.
Surely someone else that has used this program to build molds has faced this issue. Any suggestions?
Thank you in advance.
I'm using a CNC Shark HD3 Extended Bed.
-Ryan Johnson
NewRuleFX
Adding Draft to Pocket on Model
Re: Adding Draft to Pocket on Model
You'll either have to model it in 3D or use a pattern-maker's router bit (I've seen 7' and 10' ones but not the 8' 35" you're looking for).
- IslaWW
Use a tapered end mill for your pocketing. These are common for machining drafts in the mold making industry. You may not get exactly the 8.53* side angle you are looking for , but you should be close
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
- Model of CNC Machine: Next Wave Shark HD3 Extended Bed
Thank you.
I do have some tapered bits, I will give that a shot. I'm guessing that the best way to go would be to do the majority with straight bits, and then do a last finishing pass with a bit change to the tapered bit.
Thanks guys.
-RJ
Thanks guys.
-RJ
- TReischl
Yup, the tapered bits are the way to go, much faster than doing a 3D cut. Also will get a better finish.
- Model of CNC Machine: Laguna MCNCIQ
I need to make similar cuts now and then, and I have found that it's fairly reasonable to order custom bits (I order mine from Orbit Tools: http://www.orbittools.com/). I just got tired looking for special bits and once I did find something it was often only "almost right" anyway, so I find it well worth the investment. Any shank length, any length of cut, any angle, up spiral, down spiral etc, you get them made exactly the way you want them. The ones I have bought have varied between (if I remember correctly) $140 and $190 so they're not exactly cheap, but it's still in line with what you have to pay for many high end standard bits. And the pleasure of having a bit that's 100% right for the job is priceless.newrule wrote:Thank you.
Thanks guys.
-RJ
