I am using the latest Aspire 8.5. I open the help and the reference manual installed by the latest download, and I only see the Carve Pro stuff. What am I doing wrong. I need to study the 3D modeling, which is not included here.
thanks,
Chris
where is 3D modeling in the reference manual
- Model of CNC Machine: CNC Shark Pro HD
Re: where is 3D modeling in the reference manual
Hello,
Did you select the Help Contents item from Aspire Help menu?
You can also access the reference manual by using the Open Application Data Folder… from the File menu. It will open a Windows Explorer window with a link to the pdf file.
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
Page 136 onwards of the Help Contents should be the modelling tools. The first page is interactive so clicking on the modelling tools tab picture there should take you to them.
There is no manual for 3d modeling. Just the tools used in the modeling process.
