All the Vectric Projects etc are set in Imperial measurements.
Virtually all my cutters are Metric. If possible I want to avoid having 2 set of cutters (Metric and Imperial.)
Question:- Can I just use the nearest Metric equivelant cutter. Or have I got to dig into the piggy bank, and purchase more ?
Any advice will be MOST welcome
Metric and Imperial Tools
Re: Metric and Imperial Tools
I use both imperial and metric. Your tool database has two sections, which is self explanatory.
Doesn't matter if the tool is imperial or metric just so long as it's the right tool for the job.
Whether you can use a 12mm tool instead of 1/2" tool (for example) depends on the project. 99% of the time it would make no difference after recalculating the project but if the project was made in 1/2" material and relied on 1/2" slots then it would.
I know people just use the default toolpaths that Vectric supply but in reality you aren't learning anything by doing that & really the toolpaths should be checked to ensure you are not exceeding the speed & feed settings for the machine you have.
All you really need to do with any of the Vectric projects is to re toolpath them using metric rather than imperial tools
I actually normally go a step further & convert the whole project to metric but that's just me, there is absolutely no reason you have to do that
- Model of CNC Machine: CNC Shark
Vectric is good about letting you mix and match units. I do all my design in imperial units, but I have bits in 1/4" and 6mm. I just select the bit I want without worrying about the units. Once the bit is in the database, Vectric takes care of the rest.
- Model of CNC Machine: GX-6060 CNC Router Table
Wow !, As always you are ALL just so helpful.
I can now make progress ( I hope)
