Strange tool path
dcgayhart
Model of CNC Machine: stinger 1
Strange tool path
Post by dcgayhart »
When I created the tool path for the escapement on my clock and did the preview it looked good:
When I cut it on the Camaster Stinger it came out like this:
Any ideas what happened? I have cut 15 gears and the frame so far and nothing like this has happen.
IslaWW
Re: Strange tool path
Post by IslaWW »
Only a guess here, but any chance that you previewed the file with a 1/4" bit and cut it with one that was larger?
GCnC Control
Post by Rcnewcomb »
I'd agree with Gary. It looks like it was cut with a larger bit than was specified in the preview.
dcgayhart
Post by dcgayhart »
I cut it with a .25 end mill, same as in the tool path setup.
Post by Rcnewcomb »
Can you post the file?
sawmillsam
Post by sawmillsam »
Or maybe you cut ON the vector instead of OUTSIDE of the vector...?
dcgayhart
Post by dcgayhart »
I'll try it again tomorrow with a fresh file. Let you all know.
BrianM
Post by BrianM »
Also check that the tool defined in the tool database with 0.25 or whatever in the NAME really has a diameter of 0.25" set in the fields. I've often copied a tool, renamed it, but forgotten to actually change the diameter!
Brian
dcgayhart
Post by dcgayhart »
Tool seems ok here's file
escapment.crv3d
(901 KiB) Downloaded 138 times
Post by Rcnewcomb »
The bit diameter is defined as 0.125 in your file
dcgayhart
Post by dcgayhart »
Yes, we have two computers in the shop. one has the wrong tool description. thanks
