Gadgets for V8
Gadgets for V8
Postby joeporter » Thu Feb 26, 2015 8:38 pm
I just purchased the new version of Aspire. All is well with the install, everything seems to work OK. However, the gadgets I had in the older version didn't automatically cross over to the new version. Do I have to re-load all the gadgets from Vectric or is there an easier way to move them on my computer? Any help would be appreciated....joe
joeporter
Re: Gadgets for V8
Postby Adrian » Thu Feb 26, 2015 9:44 pm
Easiest way is to re-install them unless you're confident using Windows.
They are installed in your Public Documents folder under Vectric Files if you want to try copying them manually.
Re: Gadgets for V8
Postby ohiolyons » Thu Feb 26, 2015 10:06 pm
tried re installing it wants to install them into 4.5
CNC in Kettering, Ohio
ohiolyons
Re: Gadgets for V8
Postby Adrian » Thu Feb 26, 2015 10:12 pm
Have you downloaded the gadgets from the gadgets site again or are you using the install files you used to install previously?
Re: Gadgets for V8
Postby ohiolyons » Thu Feb 26, 2015 10:21 pm
redownloaded, I deleted the old ones didn't want to check version numbers and I figured the gadgets would have to be installed anyway.
ohiolyons
Re: Gadgets for V8
Postby ohiolyons » Thu Feb 26, 2015 10:47 pm
recreated the gadget folder for 4.5
added the gadgets to 4.5
copied gadgets from 4.5 to 8.0 folder and they show up
ohiolyons
Re: Gadgets for V8
Postby Adrian » Thu Feb 26, 2015 10:51 pm
I've raised a query with Vectric as gadget installation into V8 was working but like you I can't get any of them to install directly.
Re: Gadgets for V8
Postby ohiolyons » Thu Feb 26, 2015 11:22 pm
Always glad to see it is not OE (operator error)on my part
ohiolyons
Re: Gadgets for V8
Postby joeporter » Fri Feb 27, 2015 3:30 am
OK, thanks, guys, I think I have a plan, will try in the morning...joe
joeporter
Re: Gadgets for V8
Postby mfirlott » Fri Feb 27, 2015 3:52 pm
Good to hear that a gadget copy will work. I'll try that tonight. Otherwise...AWESOME.
As an aside, I do indexing work so I looked at the Wrapped Job Setup Gadget to see if it was enhanced in any way. Unfortunately not but I noticed that the Rounding Toolpath is now gone from this gadget. Is there a way to get that piece of the gadget back? I use it every time as I find it more precise than cutting the corners off my stock on the tablesaw.
(Mitch)
CAMaster Stinger I
Vectric Aspire v8
Epilog 45watt Helix Laser
mfirlott
Re: Gadgets for V8
Postby BrianM » Fri Feb 27, 2015 4:00 pm
Hi,
The gadget installers on gadgets.vectric.com have now been updated for V8.
Brian
Brian Moran
Chairman
Vectric Ltd.
BrianM
Re: Gadgets for V8
Postby mfirlott » Fri Feb 27, 2015 4:57 pm
THANKS Brian!!!!
Is there a way to also move the Rounding Toolpath that was in the v4.5 Wrapping Gadget?
(Mitch)
CAMaster Stinger I
Vectric Aspire v8
mfirlott
Re: Gadgets for V8
Postby seanm » Fri Feb 27, 2015 6:09 pm
Hi All,
You can download the rounding toolpath gadget here
http://www.vectric.eu/update/gadgets/v7 ... nstall.exe
This will not install in the same place as it would have done with the software installation and will not appear under the wrapping section in the gadgets menu, it will now appear as any other gadget you install, directly in the gadgets menu with the title of Create Rounding Toolpath.
Thank you all, have a good weekend.
Sean
seanm
Re: Gadgets for V8
Postby mfirlott » Fri Feb 27, 2015 7:49 pm
GREAT! Thanks Sean.
(Mitch)
CAMaster Stinger I
Vectric Aspire v8
mfirlott
Re: Gadgets for V8
Postby gwandad » Wed Dec 02, 2015 10:20 am
Good on you Sean. You saved my sanity.
It was on my PC, but not my laptop (the working machine) but both loaded from the same disk!
Even after a reload! I'm now in business.
gwandad
Model of CNC Machine: OpenBldOXHomebuilt&designed4thAxis
Return to Aspire - General
Users browsing this forum: Jbwjim, MarkJohnston, TReischl and 25 guests
