texture pocket edges
hello all. what is the trick to getting a clean perimeter for a textured pocket? i used a 1/2 ball end bit and set the offset to .27 but it still is jagged. thanks in advance
- zeeway
Re: texture pocket edges
Not sure what you mean by textured pocket. A picture is worth a thousand words...
Angie
Angie
- mezalick
This is from Jamie Oxenham.
Same idea,,,works real well..
I use it all the time.
http://fromaspiretobeyond.blogspot.com/ ... t%20repair
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- jimwill2
- Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Great link, Michael! See you in S.C! I'll get there Wednesday evening... do you have plans for dinner?
Jim Williams
- mezalick
I'll be there in the afternoon.
see you there.
Michael
see you there.
Michael
jimwill2 wrote:Great link, Michael! See you in S.C! I'll get there Wednesday evening... do you have plans for dinner?
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
here is the file as a jpeg. what i am talking about is the jagged edges as borders. i used half of the dim of bit as an off set.
thanks
thanks
- mezalick
Sorry rockjoe,
From the picture you attached the process that Jamie developed should work great,,,I think,,If I understand your picture.
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
thank you all im going to give it a whirl!
