rotary index aspire
Re: rotary index aspire
Postby PATRICKCUES » Mon Mar 19, 2018 11:43 pm
The wrapping job doesn't do what I'm looking for. I'm cutting a pocket at 0 and then cut another of the same pocket at 90 and another at 180. Individual pockets. Not wrapping .
Vcarve and aspire doesn't support this. Rhino does it what i was just told from Laguna
PATRICKCUES
Model of CNC Machine: LAGUNA IQ
Postby Wayne Locke » Tue Mar 20, 2018 4:20 am
Maybe I am unbelievably dense but here is a shaft with 4 inlays 90 deg apart and cut with one file.
If this is not what you are looking for would you post a better description or a drawing because this seems to meet your requirements, pockets 90 deg apart and one toolpath.
Wayne Locke
Postby Leo » Tue Mar 20, 2018 12:40 pm
I don't think you are unbelievably dense. You have a good handle on how the wrapping routine works.
In my first post in this thread, I said that it is possible to do it as a wrapped job, though I have not tried it.
I do understand the posters position on this and I do think that Vectric could be better if it were a bit more capable on the full 3D side of things.
It's always a personal choice as to what a person wants to use and do. Therefore, the poster can choose what they want. The poster wants it to operate in a particular manner. I agree with him, and wish the same thing. However what he wants requires some G-Code editing. For some of us that is simple, but for others of us, not so simple. Maybe somday, Vectric will do this sort of thing, maybe not. Again a choice. I do know that the competition to Vectric is FAR more expensive, and not as user friendly.
I also hope that someday Vectric will come up to speed on full 3D machining.
I think though in your last example, maybe the bottom of the pocket is radiused and not flat? That could be an issue.
www.leosworkshop.com
Leo
Postby 4DThinker » Tue Mar 20, 2018 12:42 pm
Pockets done with the wrapping feature have sides that are radial (toward the center of the turning) rather than vertical. Anything other than a simple single plunge or vertical line with no sideways movement has this flaw when all X (or Y) moves are changed to A (or B) moves.
I'm often cutting mortises for stretchers on 2 sides of turned legs. My mortise slots only match my tenon cuts if done as indexed X/Y/Z cuts with A only moving when I need to rotate to the second side.
4DThinker
Postby IslaWW » Tue Mar 20, 2018 1:33 pm
Wayne...
Unless they are incredibly thin the pockets for inlays on a rotary blank need to be cut without rotation so that the inserts can also be cut on the flat. If not, like stated above, the bottom will be radiused and the radial sides will be angled and the axial will be perpendicular making it impossible to cut a matching inlay.
In most cases pendant controls do not have the ability to perform exact moves, i.e. 90*. That is why it must be added manually to the file or employ the trickery that I mentioned above.
Possibly for this user a number of simple files could be made with relative moves for the rotary axis. They could be called up at will. Something Similar to:
G91 G0 B90
G90
Or exact positioning like G0 B90, 120, 270, 60, etc. Those files could be called up from file storage and executed in a second or two, then the pocket file rerun.
CNC Technology & Training
IslaWW
Postby Leo » Tue Mar 20, 2018 3:30 pm
I wasn't even thinking of the sides, but that is a good point. That alone takes the wrapping out of the picture.
Leo
Postby TReischl » Tue Mar 20, 2018 8:53 pm
One issue that has not been brought up is cutting "off axis" on the rotary.
What is meant by that is when the rotary is positioned the tool cuts off the centerline of the rotary axis during XYZ milling routines.
The further the cutter is from the center line of the rotary axis the greater mechanical advantage it has. Most rotaries that allow this type of machining have a "clamping" ability. The rotary positions, and then a clamp locks the axis in place during cutting. This prevents the force of the cutter from overcoming the drive motor.
On a pool cue using small cutters I doubt it would be a problem, but for those of you thinking about doing larger diameter work, do some serious thinking about how you will lock that axis during the cut.
Myself? I just took the simple route for doing this stuff. I made an indexing plate that attaches to the rotary axis. It is a plate with lots of holes precisely placed. Behind it is a piece that has a pin that engages the indexing plate, locking it in place. Virtually the same thing as seen on many lathes for indexing work. When I use it there is no power to the rotary axis so I can turn it by hand. OMG!!! By hand!!!! It works. For me, doing a whole bunch of thinking and fiddling around to get it to work under program control is just not worth the effort.
http://www.tedreischl.com
Low Profile CNC Router Vise
Postby lawrence » Thu Jul 26, 2018 3:17 pm
Would it be possible to do v-carve inlays around the rotary? This would alleviate the sides issue
lawrence
lawrence
Model of CNC Machine: CNC Shark HD
Postby phill05 » Fri Jul 27, 2018 9:36 am
I made a push button controller that I could connect to my indexer independent of the cnc that can use degrees, divisions or full rotary at the manual push of a button
In my code I insert a pause of 5 seconds that allows me time to press a button, indexer moves to next position cnc cuts waits for next index move then cuts again.
Another good point is I can take the indexer and controller put it on a milling machine to cut a job, I have even used it on a saw table to cut an 8 segment tapered end on some shafts.
Phill
phill05
Model of CNC Machine: Hybrid re-build
Postby Greolt » Sun Jul 29, 2018 12:50 am
I often use a rotary axis as an indexer to do repeat operations at a number of equally spaced positions.
I add this snippet at the end of the code,
G91 G0 A90 (whatever angle required)
G90
M47 (repeat program from first line)
Certainly not something that would be used in a production environment, but works for me.
Greolt
Model of CNC Machine: 900 x 750 2hp Mach3 Router & others
Postby PATRICKCUES » Thu Aug 09, 2018 9:34 am
This is what I'm doing
PATRICKCUES
Postby Bobtail Farm » Thu Aug 09, 2018 2:26 pm
Sweet. Is the signature hand written, or did you inlay that too? :-)
Bobtail Farm
Postby PATRICKCUES » Sun Aug 12, 2018 8:45 am
No I hand sign all of my cues
PATRICKCUES
rotary index aspire
Postby Bobtail Farm » Fri Aug 17, 2018 12:54 pm
Thank you.
Bobtail Farm
Postby PATRICKCUES » Tue Aug 21, 2018 3:15 am
Wayne Locke wrote:Maybe I am unbelievably dense but here is a shaft with 4 inlays 90 deg apart and cut with one file.
I would like to talk with you. To see how you did this.
If you would give me a call please
Thank you
Doug Patrick
6187092615
PATRICKCUES
PreviousNext
Return to Aspire - General
Users browsing this forum: No registered users and 20 guests
