Know what software was used to generate these?
Postby JimmyD » Mon May 14, 2018 10:14 pm
Does anyone know what software was used to generate these type of designs?
Jim
JimmyD
Model of CNC Machine: ShopBot PRSalpha, custom rotary indexer
Re: Know what software was used to generate these?
Postby martin54 » Tue May 15, 2018 12:27 am
Would imagine it could be lots of different programs, Aspire will more than likely do that sort of work, the first picture for sure, the other 2 I don't have enough experience with it to say :lol: :lol:
Postby JimmyD » Tue May 15, 2018 4:18 am
Yes, Aspire might be able to, but you would have to feed the 3D curves information to it. That is what I'm trying to find out. The source of the 3D curves.
JimmyD
Postby LittleGreyMan » Tue May 15, 2018 10:35 am
This kind of design may be a grey scale conversion of a 2D image.
So it will be very difficult to find what software is able to generate these 2D drawings, except if somebody on the list recognizes a typical pattern.
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Postby jonnylbluejeans » Tue May 15, 2018 12:24 pm
The second one looks straight out of photoshop using the cloud functuons and some chroming
jonnylbluejeans
Model of CNC Machine: X-Carve 1000mm
Postby CarveOne » Tue May 15, 2018 12:33 pm
Photos #2 and #3 were made with multiple layers of color wood laminates. The pattern of vectors used to create the negative 3d model should be well within Aspire's capabilities. The color laminates in #2 makes this look much more complicated than it really is. This laminated wood is used in making some popular rifle and pistol stocks and turned pen blanks.
CarveOne
CarveOne
CarveOne
Postby Mike-S » Tue May 15, 2018 3:08 pm
CorelDraw has fills like "swirl" and "mask" that look similar. Import as bitmap and convert to component, then carve in a plywood type material.
Mike-S
Postby Mike-S » Tue May 15, 2018 3:19 pm
This is another fill called "epidermis."
Probably any good drawing program will have similar texture fills.
Mike-S
Postby JimmyD » Tue May 15, 2018 11:33 pm
Thanks for all the good comments!
JimmyD
Postby dealguy11 » Wed May 16, 2018 6:02 pm
I know this isn't a Corel board, but I'd like to set something like this up in Aspire. I have CorelDraw but don't use it enough to be proficient. How do you set up these fills?
dealguy11
Postby Mike-S » Wed May 16, 2018 11:07 pm
Click the "Fill" tool bucket and select the "texture" fill from the fly-out.
That will give thousands of possible fills.
Mike-S
Return to Aspire - General
Users browsing this forum: No registered users and 25 guests
