Can't add tabs in VCarve Pro...
Postby harryball » Fri Jan 12, 2007 9:58 pm
Why can't I add tabs to an open vector in VCPro?
I can check the box and edit 3D tabs but when I click to add a tab it does not add them. Am I missing something?
I realize the vector is open but it's cutting small squares out and the most efficient path is to just cut a grid so the bit doesn't travel each path twice.
Robert
Robert
http://www.habitatforbats.org
Give a Bat a Home!
harryball
Model of CNC Machine: ShopBot PRT Alpha
Postby dighsx » Fri Jan 12, 2007 10:17 pm
Can you post an example of what you're trying to do?
Take it easy.
Jay (www.cncjay.com)
dighsx
Postby BrianM » Fri Jan 12, 2007 11:28 pm
Robert,
The tabs don't work for the 'Machine Vector .. On' strategy (which is the only one you can use for open vectors). When I implemented the tab function I assumed that what people wanted them for was cutting parts out, so the code was written to support the machine inside and outside strategies, which are the main stragies used for cutting parts out as they take account of the cutter radius.
Unfortunately I didn't grey out the option for the machine vectors on strategy which has led to a great deal of confusion.
I have learnt the error of my ways and the next version of the software will support tabs for the Machine Vectors .. On strategy
Brian
BrianM
Vectric Staff
Users browsing this forum: No registered users and 28 guests
