need help with vector grouping
Postby coop » Mon Nov 13, 2006 9:54 pm
i am trying to profile cut names
and want to be able to select certain vectors that
need to be cut in the same tool path but can not be easily selected using
the click on or the rectangle selection methods !
i alson tried the ctrl+g but i must be missing something ?
help
coop
coop
Model of CNC Machine: K2CNC- 25X25-50X50
Postby Paco » Mon Nov 13, 2006 10:02 pm
Dragging the select tool doesn't behave the same from right to left VS left to right... CRTL-G to group, CTRL-U to ungroup. Grouped are solid, ungroup are dashed...
What's your problem?
Paco
Postby Tony Mac » Mon Nov 13, 2006 10:41 pm
Hi Coop,
Are you trying to select Text that's been created in VCarve Pro?
If this is the case the letters are already grouped together as a Text object.
Clicking on one of the letters will select the complete block of text and this
can then be Profile machined.
If you are not working with Text,
Hold the Shift key down and click the Left mouse on each vector to select.
The selected vectors will be drawn as dotted lines.
Press Ctrl +G to group the selection into a single object that can then easily be selected.
Let us know if this has missed the point?
Tony
Tony Mac
Vectric Alumni
Postby coop » Mon Nov 13, 2006 11:24 pm
the text was created in coreldraw and exported as curves
i will tryyour suggestions and keep you posted
thanks
coop
coop
Postby coop » Tue Nov 14, 2006 1:05 am
so i tried to hold the ctrl+g while selecting vectors but as one was clicked on
the other became unselected.
i guess that command does not work as a "multiple select" command would.
i would simply like to select several vectors that cannot be selected any other way
thanks
coop
Postby Tony Mac » Tue Nov 14, 2006 1:10 am
Wrong key selection
Hold Shift key down and Click Left on vectors to add them to the selection - all shown as dotted lines
Then, release the Shift key and Press Ctrl +G to group the selected objects together.
Alternatively, use the Group / Ungroup icon on the Edit Vectors menu - 3rd icon along
I hope this helps,
Tony
Tony Mac
Vectric Alumni
Postby coop » Tue Nov 14, 2006 2:12 am
thanks Tony,
that was exactly what I was looking for !
coop
coop
Users browsing this forum: No registered users and 38 guests
