Tabs and the plunge speed
Postby Jason Marsha » Sat Nov 04, 2006 9:04 pm
I had a small issue when cutting tabs a few minutes ago. The plunge rate to form the second side of the tab was too fast, when I checked, VCarve had not adjusted the plunge rate and therefore it was plunge cutting the other side of the tab at the feed rate.
Is this going to be changed for the next version?
Jason
Jason Marsha
Postby BrianM » Wed Nov 08, 2006 2:00 pm
Hi Jason,
Sorry for the delay in replying - I missed the post originally.
I've now logged this as a bug and will change it for the next version so that the plunge at the end of the tab will be done at the 'plunge' feed rate. I will leave the 'plunge' side of 3D tabs as normal feedrate.
Regards
Brian
BrianM
Vectric Staff
Postby Jason Marsha » Wed Nov 08, 2006 9:04 pm
Thanks Brian, that change would be great.
Jason
Jason Marsha
Postby Jeff E. » Sun Nov 26, 2006 2:40 pm
BrianM wrote:Hi Jason,
Regards
Brian
Brian,
Any chance you can make the end of the 3D tab at plunge rate also? Or selectable? I use tabs a great deal in metal cutting and have trouble breaking end mills at the end of tabs. After reading this thread I have switched to 3D tabs but still occasionally break an end mill unless I slow the feedrate way down.
regards,
Jeff E.
Jeff E.
Users browsing this forum: hooby, Mark Bolton and 12 guests
