SCM TECH Z 25
SCM TECH Z 25
Postby LaserKitchen » Thu Oct 12, 2006 6:58 am
W are useing a SCM TECH Z 25 cnc . Any information on running V Carve Pro on this type of machine .The operating program is Xilog Plus with a .pgm (own type of extension ) and the normal .dxf format . Any help will be appeciated.
Regards
CHRIS
LaserKitchen
Postby Tony Mac » Thu Oct 12, 2006 10:26 am
Hi Chris,
We have a postprocessor that's been written for a Morbidelli running with the Xilog Plus (metric) controller.
I've e-mailed the postp directly to you along with a note on how to test the output using the Trial version of VCPro.
Please let us know if it works or needs modifying.
Tony
Tony Mac
Vectric Alumni
Postby Tony Mac » Sat Oct 14, 2006 10:19 am
Hi Chris,
Have you had a chance to test the SCM postp?
Tony
Tony Mac
Vectric Alumni
SCM TECH Z 25
Postby LaserKitchen » Wed Oct 18, 2006 4:51 pm
Hallo Tony
Thanks for your reply
Have recieved the file and copied it into the folder. It does show in the dropdown list of the toolpaths. If i save the toolpaths as a .pgm and try to open the toolpath file .pgm in xylog plus it gives me an error [13,4] EDITdb:(........vcarve2.pg_) file not found.
Not sure how to fix this.
I would really like to see if this program would be able to work on my machine.
Im really interested in purchasing your program.
Chris
LaserKitchen
Postby Tony Mac » Wed Oct 18, 2006 6:47 pm
Hi Chris,
The filename information (vcarve2.pg_) is not included inside the toolpath file created by the
postprocessor so I guess the error message is related to the toolpath filename and a database?
The SCM Xilog Plus control usually requires an .XXL file extension and I wonder if your setup could use this option?
Tony
Tony Mac
Vectric Alumni
Tech Z 25
Postby LaserKitchen » Sun Oct 29, 2006 10:21 pm
Hi there thanks for your reply . Still a struggle to find .XXL extension .As all our programs exported from Xilog Plus to Panel Mac with a program called " Paddle " have an extension .pgm The CNC actully operates on the Panel Mac software . Hope to solve this bug soon Thanks Chris.
LaserKitchen
Postby ACWORX » Thu Jan 04, 2007 6:08 pm
HI CAN YOU SEND ME THE POST FOR THE SCM XILOG 3MM
ELI
ACWORX
Postby Tony Mac » Thu Jan 11, 2007 11:10 pm
Hi Eli,
Have you received the SCM postp we e-mailed to you yesterday?
Tony
Tony Mac
Vectric Alumni
Users browsing this forum: Jim_in_PA and 16 guests
