Toolpath problem
Toolpath problem
I have a problem I don't understand. The attached CRV consists of four closed vectors. Toether they form a circle with an enclosed curved diamond. If I select all four vectors and VCarve a toolpath I get crazy results, some of the cuts are outside of the vectors. However if I select and toolpath one at a time or two closed vectors opposite each other I get the expected results. I'd like to use this design to create a border consisting of quite a few of the circles with the enclosed curved diamond. I should be able to copy and paste the design, select all of the vectors and create one toolpath. The way it works now I won't be able to do that. That's what I don't understand.
- (66.86 KiB) Downloaded 70 times
- Diamond.crv
- (87 KiB) Downloaded 189 times
I see now that the file was bigger than necessary, but you have to adjust to your size.
( I work in metric.. )
I think your problem was that you had overlapping in the vectors.
The total circle was not good either, so I made a new one.
CNC 1000x600 | VCarve Pro 5.5 | PhotoVCarve | Cut3D | Summa Vinyl Cutter | FlexiSign
- Paco
Overlapping vector is the problem...
- (41.7 KiB) Downloaded 114 times
This is the border I wanted to design. Once again, thanks for the help.
- Diamond border.crv
- (564 KiB) Downloaded 202 times
- (77.93 KiB) Downloaded 125 times
