V-Carve Wizard suggestio for enhancement
Postby Tony Mac » Wed Feb 08, 2006 7:53 pm
Hi everyone,
Excellent ideas and please keep posting them.
The more information and supporting evidence you can supply on why something would be useful, really will make a difference to our understanding of exactly what's needed.
Regards,
Tony
Tony Mac
Vectric Alumni
Option to eliminate background on preview
Postby Rcnewcomb » Wed Feb 08, 2006 10:43 pm
I would like the option to not have the blue background saved with the preview, i.e. just save the material and drawing in the preview file.
Postby Wemme » Sat Feb 11, 2006 5:32 am
Heres one That I would like to see.
Time is very important here as we need to compete with cheap imports.
Say if you need to pocket and area.
first I want to use a big cutter to do the bulk of the cutting (problem is, it won't fit in all the places such as around text etc)
second I want to use a small cutter to do the bits the large cutter can't but not to do all the bit that have already been done with the large cutter (i.e save time)
Is this something that others would find of use?
Cheers
Bart
Wemme
Wemme Reply
Postby hbhbbb » Sat Feb 11, 2006 1:58 pm
Tony et al,
At the risk of sounding greedy.....
Yes, it would be helpful to be able to hog out bulk material with a big bit, and then hit the details with a .125.
hbhbbb
Postby Perry » Sat Feb 11, 2006 2:24 pm
Regarding "hogging out", here is a work around that I have used. In VCW, create an island around the items yo wish to spare from the large bit, and create an offset inside the perimeter of you projects border. Using the 2D tooling, "pocket" these areas with the larger bit.
Now the remaining islands, cut as you would normally.
Like I said, a "work around" that seems to work for me.
Perry
Model of CNC Machine: Modified Shopbot PRT96
Hogging out
Postby Phil » Sat Feb 11, 2006 5:25 pm
To a limited degree we can do "hogging out" with flat clearance V-Carving. Select a small ballnose bit for V-carving and a .5 or .75 inch endmill for the flat clearance option.
I we could select a small end mill for the V-carve part of the toolpath we could square up the edges of the cut and perhaps have the ability to do inlay as well.
I did the attached Buffalo with a .125" ball nose bit at.5" deep and the flat clearance with a .5" end mill.
(40.33 KiB) Downloaded 427 times
Phil
Remembering settings
Postby Rcnewcomb » Mon Mar 06, 2006 7:22 pm
I would like Vcarve Wizard to remember the last setting of:
View/Use Shaded Background
and
Animate Preview
or at the very least allow me to default those features to "OFF"
Postby Phil » Wed Mar 08, 2006 11:14 pm
I've been playing with different ways to take a V-carve file and reverse the carving so that the resulting cut would produce an image that stands out from the background rather than cut into the surface. It occured to me that if there was a feature in V-Carve Wizard that would reverse the Z coordinates, that is change the negative Z values to positive values, the effect I refer to could be achieved. This feature could be incorporated into the "flat area clearance" toolpath strategy to achieve a carving with a recessed background and a raised image. I think this would be a really cool feature. What do the Wizards think?
Phil
Reverse v-carving
Postby Rcnewcomb » Thu Mar 09, 2006 6:53 am
Phil,
That capability is already there. The way to "raise" is to draw another shape around what you want to reverse v-carve.
Check out this link for a brief tutorial:
http://www.222artisans.com/vcarve.html
Postby Paco » Thu Mar 09, 2006 4:42 pm
Tabs, tabbing, bridges.
Sign along...
:wink:
Paco
Reverse V-carving
Postby Phil » Thu Mar 09, 2006 5:10 pm
we can cut raised images like the raised V on the http://www.222artisans.com/vcarve.html web site but that is not the same as the reverse V-carving I am refering to. If we were to reverse the teardrop image at the top of the 222artisans page there would be a taper along the length of the image. The raised carving we can do now would leave the teardrop flat across the top in the same way that the V on the 222artisans web page is.
Phil
Postby Rcnewcomb » Thu Mar 09, 2006 5:34 pm
Phil,
Now I understand.
The program would need to local a center line for each object as it does now, convert the depth to a height, and toolpath to hog out anything that isn't part of the bevel.
Like the picture shown below?
(49.68 KiB) Downloaded 811 times
Postby Phil » Thu Mar 09, 2006 5:59 pm
That's exactly right. Knowing absolutely nothing about programming it seems to me that simply changing the Z values from negative to positive would acomplish this. It's probably more complicated than that.
Do you have any idea what our friend Paco is babbling about?
Phil
Postby Paco » Thu Mar 09, 2006 6:35 pm
Babbling about something to hold part in place while cutting 'em out...
Which one would you like?
... or are you looking for something different?
Hey good tutorial Rcnewcomb!
(48.68 KiB) Downloaded 364 times
(49.97 KiB) Downloaded 373 times
(52.21 KiB) Downloaded 361 times
Paco
Postby Phil » Thu Mar 09, 2006 7:32 pm
Pretty cool Paco. How did you do it? Expensive software such as Artcam or Insignia, or special technique.
Phil
PreviousNext
Users browsing this forum: gordread and 39 guests
