I was playing around with offsetting vectors as part of doing an inlay and ran into this. If I want to use an 1/8" tool and I attempt to offset the target vector by the tool radius as part of that, I'm limited to 3 decimal places in the offest distance box such that I can only input 0.063" instead of the true 0.0625". Is there a way to increase the number of available decimal places somehwere that I am missing? Anyone know why the limitation would be there or experience something similar? By the way, I'm trying this with 2.1 Beta. I haven't gone back and tried it using version 2.0.
Jon
Increase number of decimal places available for offset
- BrianM
- Vectric Staff
I'm afraid I have to plead guilty to that one . As we are based in the U.K our native measurement units are mm and 3 decimal places in mm mode is 0.001mm which is 0.0000393 inches, which is pretty small by anyones standards. Obviously in inches, 3 decimal places is only accurate to one thousandth of an inch.Anyone know why the limitation would be there or experience something similar?
We will fix this in the next release to make the offsets support 4 decimal places in inch mode for our customers using inches, and wanting offsets to less than one thousand of an inch accuracy. However, as the difference between 0.063" and 0.0625" is literally half a thousand of an inch, unless you are using a high accuracy engraving machine you are unlikely to see a difference on most routers.
Regards
Brian
