Hi
Is there a way to zoom in on a rendered tool path? I have a large design with intricate work and it's impossible to see what the results are without cutting.
Dale
Is zoom possible on rendered toolpath
- webwizard2
- dighsx
Hey Kimon check out this thread and download the shortcut key sheet for VCarve Pro you might find it handy: http://vectric.com/forum/viewtopic.php?t=431&start=12
Take it easy.
Jay (www.cncjay.com)
Tip for zooming into a region in the 3D window.
Click and hold the Left mouse button to Rotate the design into the approximate position.
Click and hold the Left + Right mouse buttons together to Pan = move the design so the region of interest is in the Middle of the screen.
Click and hold the Right mouse button - Push = zoom in and Pull = zoom out.
Important - use Pan (Left + Right) to continually move the required region into the middle of the screen before Pushing with the Right mouse button to continue zooming in.
All sounds a tricky but soon becomes second nature.
Hope this helps,
Tony
Hope this helps,
Tony
- dighsx
Also if you have a scroll wheel on your mouse rolling it forward zooms in and rolling backwards zooms out.
Take it easy.
- webwizard2
