Hi Not Sure
Did you pocket cut with the ½ “ endmill it calls for in the program. If you cut with a 1/4 ‘endmill when you programed for a ½ “ you would get that result. The pocket cut almost looks like it was cut with a ball nose bit or is it just the picture?
Dan
Yeah, I would assume you used a smaller tool bit diameter (on the machine) than the one entered in the progam (1/2" CED)... are we right?!
You seem to use a V bit with a very wide flat point; may I suggest to get more pointy tool so you jsut be even more happy with such work... is that part of you queastion?...
You guys are good! I did use the wrong bit. I used a 1/4" spiral bit instead of a 1/2". I switched from 1/2 to 1/2 when drawing to reduce cut time and then fogot when it can time to cut. My V bit does have a wide flat point, what is the norm? Should the V-bit come to a sharp point?
Bit configuration is up to you only (well, maybe your customer) but pointy tool make V Carvings sharper/more detailed if you ask me. It's not because it's flat point that it mean it's wrong or bad, it's just a matter of what your looking for. V bit with a flat point are less prone to breakage... I personally never have break any yet though.
I would say that V bits that come to a point are the norm. If you call up a V bit tool in the tool database V C Pro assumes it has a point. The V bit you have with the flat bottom should be entered in the engraving tools. Engraving tools have a place to enter the flat bottom diameter.
Dan
