I've found several sites where vector scale-able files are available for purchase. But I have found many black and white clip art files I'd like to use. But the problem is vectorizing them without a lot of work and still have a good image to carve.
I'm wondering if anyone has suggestions on Raster to Vector Conversion programs. I've done some exhausting searching but can't afford the ones I think I need. Maybe someone has found something that I haven't run across yet. Any and all ideas appreciated....
Keep up the good work
Vectric Team.... I almost have the project out the door, Then I'll be able to download the real stuff and begin to have fun...
Don
- RoutnAbout
Try http://www.vextrasoft.com . They have a trial version which is fully functional, just water marks your dxf. As long as your image is not to big, you a can delete the water marks in vcarve wizard. Cost is $99.
Maynard
Maynard
Thanks Maynard,
I've downloaded Vextractor software and had some very good results, it even exports
in EPS format which makes it ideal to use with Vcarve Wizard.
The watermark is a pain to remove but for 99 dollers I'll be buying it.
Attached picture is a JPG image vectorized using Vextractor, toolpaths generated
using Vcarve Wizard.
6mm 60 deg tool Material Conti Board
- (109.92 KiB) Downloaded 277 times
Here's a rendering of a lobster using vextractor and vcarve. Machining time is estimated at under 5 minutes.
Maynard
Maynard
- (98.68 KiB) Downloaded 237 times
