Just recently finished building my cnc router.
New to the cnc world. Will be looking seriously at VCarve Pro.
Which router bit style/shapes/sizes should I be looking to buy to get great results with VCarve Pro & PhotoCarve?
Thanks to all that reply.
Which bits should I aquire?
Re: Which bits should I acquire?
Welcome to the Vectric Forum MJR.MJR wrote:Just recently finished building my cnc router.
Congratulations on finishing your CNC. Mine too is homebuilt, so I know the work it took to get er' done.
The type of bits are going to depend upon what type of work you plan on doing the most.
As far has the VCarving process, any V shaped cutter will give you a nice professional result.
It depends on how you use them.
A 60 and a 90 degree bit will accomplish alot for you. You will also want to get some straight cutters to profile cut your work. And since VCarve Pro now has the ability to use shape cutters, you can get a ogee and maybe a roundover.
When I started using the software all I had was a few straight cutters and one 60 degree. There was alot of things to be done with just those. Start small and work your way up to a good variety.
Let us know if we can help.
Chuck
- Wemme
Hi MJR
As chuck pointed out a couple of good 60 & 90 V cutters and some end mills will get most jobs done nicely.
Once you start working with your machine and generate business you will get a feel for what type of work you
will be doing and therefore a better handle of any special tooling needs you may have.
Just make sure your tools have a true tip and the geometry is correct.
Regards
Bart
Regards
Bart
Hi MJR,
Just in case you may not have spotted the Topic on Tooling Suppliers, the following thread
contains links to tool suppliers that Forum members have purchased from and may be of
interest to you,
http://vectric.com/forum/viewtopic.php?t=278
Hope this helps,
Tony
interest to you,
Hope this helps,
Tony
- Model of CNC Machine: Homebuilt
I did see the tool link. Seems to be lots to choose from. OK, 60 & 90 degree, but what diameters & should the bits have sharp points or a flat at the tip?
To do lithopanes, do you use the same bits or do I have to get some carving bits? Again, which would be the general purpose ones?
Is there someone or someplace to check out for routing solid-surface (corian)?
Remember to drop me a line when the demo of PRO is ready for checking out.
As the software developes will I need to upgrade my computer?
Thanks guys
Thanks guys
- dighsx
I'd get a 90 degree 0.5 inch vbit, a 0.25 and a 0.125 spiral upcut and a 0.125 or 0.25 inch ball nosed bit. After you get that then I'd think about getting some small ball nosed bit like a 1/32nd. With those bits you'll be able to do just about anything you want.
Take it easy.
Jay (www.cncjay.com)
MCLS has a good selection of bits and good prices. You should be able to tool up without spending to much money. My recommendation are about the same as Jay’s
60 degree V bits ½ diam.
90 degree V bits ½ diam. If you want to error on the side of caution get 3/4 diam.
!/8 and 1/4 inch end mills.
Large diam. straight bit for surfacing your spoil board.
Any bit that cuts wood will cut solid surface material. I even cut S.S.M. on my scroll saw with wood cutting blades.
As for lithophanes I can’t help you out. I sure the people cutting lithophanes will chime in here with their recommendations.
Dan
Edited
The Vectric programs have a tool database that you can call up. That would be a excellent place to look for tooling needs and they come in two flavors. Inch and metric.
Dan
Edited
You can get a ideal of whats required to do a litho from here
http://www.vectric.com/WebSite/Vectric/ ... arted.html
the litho's I've done were finished off with a .04 ball cutter.
Chuck
Chuck
