Need a Box?
Need a Box?
Postby jimandi5000 » Tue Nov 19, 2019 6:19 am
I have been making these for my shop.
Thoughts?
box.crv
(2.71 MiB) Downloaded 53 times
Jim
jimandi5000
Re: Need a Box?
Postby BigC » Tue Nov 19, 2019 8:25 am
Thanks, Jim for sharing,
Way too big for my machine but I wonder if I copy and paste the vectors will it work out ok
also I need to change to mm and alter the tooling. Hopefully, it will be fine
Regards
C
BigC
Model of CNC Machine: Workbee
Re: Need a Box?
Postby Adrian » Tue Nov 19, 2019 9:29 am
You don't need to change to mm. The post processor does that for you. You can work in whatever units you like within VCarve (even a mixture of both) and, when you save the toolpaths, it will all be converted to the same set of units.
Re: Need a Box?
Postby BigC » Tue Nov 19, 2019 9:34 am
Adrian wrote:You don't need to change to mm. The post processor does that for you. You can work in whatever units you like within VCarve (even a mixture of both) and, when you save the toolpaths, it will all be converted to the same set of units.
I didn't know that Adrian, please excuse my ignorance.
But do I still have to change my tooling bits to mm?
Regards
C
BigC
Re: Need a Box?
Postby Adrian » Tue Nov 19, 2019 11:35 am
Regards
C
They can be anything you want them to be as long as they match what you're actually using. I often do jobs with 3 or 4 toolpaths where half the tools are metric and the other half are imperial.
Re: Need a Box?
Postby cusoak » Tue Nov 19, 2019 12:07 pm
Jim what size are the boxes
Jeff
cusoak
Re: Need a Box?
Postby jimandi5000 » Tue Nov 19, 2019 9:03 pm
cusoak wrote:Jim what size are the boxes
Jeff
13 inch wide
12.5 inch High
16 inch long
Mattel is 1/2 inch plywood
Jim
jimandi5000
Re: Need a Box?
Postby Bob Jr » Tue Nov 19, 2019 9:27 pm
Jim,
Thank you for the file. It's a nice design, and I'll be using it eventually. I just need to store it where I can find it again.
Bob
hammer...nails...stuff
Bob Jr
Model of CNC Machine: Axiom, Shark
Users browsing this forum: brucem26, dealguy11, Google [Bot], Ollie and 34 guests
