Bad simulation
Bad simulation
Postby cusoak » Mon Nov 18, 2019 1:57 pm
I have a file here that will not show the simulation of all of the tool paths to cut pockets for finger joints
I have attached the file, could some one look at it and tell me what is wrong
Jeff
Bad simulation.crv
(41 KiB) Downloaded 16 times
cusoak
Re: Bad simulation
Postby Adrian » Mon Nov 18, 2019 2:06 pm
You'll always have issues if the rectangles are the same width as the tool. It's due to internal rounding in the software. You can use a single straight line vector and do a profile cut on the line instead. Alternatively make the rectangles a fraction bigger or "lie" about the tool size by setting it as 0.249" rather than 0.250".
Re: Bad simulation
Postby cusoak » Mon Nov 18, 2019 2:44 pm
Thanks Adrian as always. I will try th single line vector and see if I can make that work.
What I am trying to do is to be able to cut the tails and pins for finger joints in 1 design and have both boards mounted in front vertically and generate 1 cut file.
would vcarve pro 10 make what I am trying to do any easery.
Jeff
cusoak
Re: Bad simulation
Postby Adrian » Mon Nov 18, 2019 3:31 pm
cusoak wrote:would vcarve pro 10 make what I am trying to do any easery.
No it would be the same in V10.
Re: Bad simulation
Postby 4DThinker » Mon Nov 18, 2019 6:53 pm
The disadvantage of cutting finger joints on both boards of a corner at the same time is that it leaves no allowance for a slip fit or room for some glue. I often cut finger joints for my students but by cutting each end separately I can get far more creative with spacing and shape of the fingers. It rarely takes more than one VCarve file as I can usually use the same vectors for both ends with a small change in how the tool path is set up. then save each tool path as a unique file.
Some examples of the variety of joinery possible: http://4dfurniture.blogspot.com/2016/05 ... c-cut.html
4D
4DThinker
Return to VCarve - General
Users browsing this forum: brucem26, dealguy11, milo30, Ollie and 38 guests
