Diamond drag Bit recommendations
Postby Aussie » Mon Nov 18, 2019 4:32 am
Hi All,
Would like to make some Edge lit LED Signs - What is your recommendation for spring loaded bits ? 60, 90, 120 deg ? Brand etc
Thank you
Ron
Aussie
Model of CNC Machine: Axiom AR6 Pro
Re: Diamond drag Bit recommendations
Postby gkas » Mon Nov 18, 2019 5:11 am
I just used some spring loaded cheapo diamond drag bits on eBay. I think I paid $20-30 USD for them. I used mostly 90°. They came out pretty good. Turn your spindle off.
crv file https://drive.google.com/file/d/12W-6QMJs-HS-66O2zQrjirHvuRMpEEkU/view?usp=sharing
gkas
Postby Aussie » Mon Nov 18, 2019 5:49 am
gkas wrote:I just used some spring loaded cheapo diamond drag bits on eBay. I think I paid $20-30 USD for them. I used mostly 90°. They came out pretty good. Turn your spindle off.
Ok Thanks.
Did you use the engraving tool path ? if so what Pressure/Depth ?
Aussie
Postby gkas » Mon Nov 18, 2019 7:21 am
Check the crv file I uploaded to Google Drive. The link is in the text.
gkas
Postby FixitMike » Mon Nov 18, 2019 8:11 am
I ran some tests of my diamond drag bit at different pressures. There was very little difference that I could see. So now I run it at .06", which is more than enough to allow for variations in the material thickness.
FixitMike
Postby Aussie » Tue Nov 19, 2019 12:40 am
Thank you for the replies. A couple of questions.
When setting the Z 0 with a spring loaded drag bit... do you compress the bit and then set Z0
What do you consider the maximum vertical height that will be illuminated.
Here is my first attempt.
Aussie
Postby FixitMike » Tue Nov 19, 2019 1:35 am
You set the Z 0 with the diamond just touching the reference surface. The pressure setting will cause the bit to be compressed that much when it is marking the material.
FixitMike
Users browsing this forum: adze_cnc, brucem26, dealguy11, Ollie and 29 guests
