Help with 3D rough pass
Postby bbowers12 » Sun Nov 17, 2019 3:27 pm
When I start cutting this out after zeroing every thing the cut start the roughing pass about 1/4 down. So on 3/4 inch material I end up with 1/4 left by the time all passes happen. The top of the 3d rope is 1/4 below the surface of the initial wood. On the preview the image does not show this. Any suggestions on what I am doing wrong. I wanted it to
bbowers12
Model of CNC Machine: piranha xl
Re: Help with 3D rough pass
Postby Phil » Sun Nov 17, 2019 5:13 pm
From the Toolpaths page open up the material setup page. You may have a Gap Above Model set to a higher dimension than intended.
Phil
Phil
Postby SteveNelson46 » Sun Nov 17, 2019 5:15 pm
At the top of the toolpath menu click on the "Set" button and check where the model is positioned in the material.
EDIT: Phil types faster than me.
SteveNelson46
Postby Adrian » Sun Nov 17, 2019 5:42 pm
Shouldn't that show in the preview though?
Postby bbowers12 » Mon Nov 18, 2019 12:54 am
Thanks All, I ended up deleting those 2 tool paths and recreating them. That seemed to do the trick only after I messed up a good piece of cherry.
bbowers12
Users browsing this forum: Dan O, dealguy11, Ollie, ozymax and 20 guests
