Need help with joining open vectors
Postby Flubadub » Fri Nov 15, 2019 9:27 pm
I am trying to make a cutting board to fit over a sink. The sink ,manufacturer sent me a template but the manufacturer in order to achieve one of the curves they used a circle to achieve the curve. I'm tried to maintain the curve but delete most of the circle. I could not figure out how to do this so I moved the circle out of the way and used the curve tool but could not figure out how to join the ends of the curve to the existing sides of the template.
Help please, see attached Vcarve Pro file
sink template.crv
(24 KiB) Downloaded 32 times
Flubadub
Model of CNC Machine: Shapeoko 3 XXL
Re: Need help with joining open vectors
Postby Adrian » Fri Nov 15, 2019 9:33 pm
Loads of different ways of doing but in this case I would use the Interactive trim (scissors) tool to cut away the inner part of the circle, then press Ctrl-A (or drag select) to select all the vectors and press J to bring up the join tool. That will join all the continuous open vectors and leave you with one open vector that you can select and delete.
You could also delete the circle and then select the two vectors either side of the gap and use the join with a smooth curve tool to fill in the gap. That might not be exactly the same curve as the circle though so you would need to check that. Finally use the join tool to join all the other vectors up.
Postby Flubadub » Fri Nov 15, 2019 10:33 pm
Ok thanks I will try those. I appreciate the help.
Flubadub
Postby Jan.vanderlinden » Sat Nov 16, 2019 1:14 am
Like this?
sink template.crv
(20 KiB) Downloaded 17 times
I've learned so much from my mistakes, I'm thinking of making a few more.
Jan.vanderlinden
Model of CNC Machine: Xcarve
Postby jimandi5000 » Tue Nov 19, 2019 6:42 am
here you go... I have this issue and I started using layers to manage over-lapping lines.
sink templateA.crv
(22 KiB) Downloaded 11 times
Jim
jimandi5000
Postby sharkcutup » Tue Nov 19, 2019 3:18 pm
I am not exactly sure how the circle was created but there is a double line on the circle at that radius location of the circle. I thought maybe a curved line and the circle may have been grouped together but they will not separate when clicking ungroup. Strange circumstance here. Zoom in on circle at that location and you will see there are two vectors there on the circle.
Re created new circle with same diameter. Deleted original circle. Placed circle in that section of the template then used scissors tool to cut away inside diameter. Could have used Draw Curve tool also but was replicating original problem description. I then joined the vectors using join/close tool (move end points to common point) for both ends of vector.
I would also like to add that I have noted that there are several other vectors of the template that need to be joined before creating toolpaths.
Sharkcutup
Facebook: Hogan's CNC Crafts
Website: www.hoganscnccrafts.com
V-Carve Pro 9.519
sharkcutup
Postby Jan.vanderlinden » Tue Nov 19, 2019 3:53 pm
Excellent job sharkcutup.
I need to learn how to use the vector validator more often.
Jan.vanderlinden
Postby Adrian » Tue Nov 19, 2019 6:12 pm
You don't need to create a new circle. As in my reply once you've cut the circle with the trim tool the odd vector is then left orphaned and can be deleted before using the join tool to join all the other vectors.
Postby sharkcutup » Tue Nov 19, 2019 9:15 pm
Agreed!
You do not need to create a new circle. I did create a new circle because I was not able to find a way to get the stray vector un-attached from the original circle.
As Adrian has said the stray vector can be deleted before joining circle portion vector to the template vectors. Once the circle portion inside the sink template is removed using scissors tool the vectors separate whereby the stray can be deleted prior to joining remaining circle portion vector to the sink template vectors.
Sharkcutup
V-Carve Pro 9.519
sharkcutup
Postby jimandi5000 » Tue Nov 19, 2019 9:16 pm
Sorry, I was thinking the circle was a desired component.
Jim
jimandi5000
Users browsing this forum: Dan O, Ollie, ozymax and 21 guests
