Leveling a log cut off (flattening)
Postby ramblecreekrustics » Mon Nov 11, 2019 4:15 am
I have several log cutoffs that I want to flatten to carve some things on. I cannot figure out how to set up a tool path to do this. I've tried profile with a set of circles, nope, didn't work. I also tried a pocket with a .1 depth of cut set, that didn't work either, or I didn't set them up right one or the other.
I have vcarve desktop V9,5 Could someone direct me to the correct way to do this please?
Thanks for your help
ramblecreekrustics
Model of CNC Machine: Shapeoko 3 XXL
Re: Leveling a log cut off (flattening)
Postby Tailmaker » Mon Nov 11, 2019 6:49 am
You need to give us more info WHAT did not work, maybe some pics and crv files?
Tailmaker
Postby Adrian » Mon Nov 11, 2019 8:14 am
The usual way to flatten off a surface is to use a pocket cut. What didn't work when you tried that?
Postby ezurick » Mon Nov 11, 2019 9:48 am
How are you mounting the log onto the table/bed? A picture would really help. Whenever I need to surface off a piece, I use the pocket. Easy to setup and control. Like the others, what did not work with the pocket?
~ Ed
ezurick
Postby SteveNelson46 » Mon Nov 11, 2019 4:34 pm
Shopbot has a good video on YouTube on how to flatten a log slab.
https://www.youtube.com/watch?v=SbIzd1Ij_EA
SteveNelson46
Postby Savannahdan » Mon Nov 11, 2019 9:36 pm
I had an old oak slab that I flattened using a fly cut program and the first type of bit he uses in the video. I didn't even take as deep a cut as he did and my cutter left a lot of marks which required lots of sanding time. So, I'll be shopping for the better bit that uses carbide inserts. The video is well worth watching.
Savannahdan
Postby scottp55 » Tue Nov 12, 2019 12:17 am
Love that vid 'cause it starts with a couple shots of my machine and firewood/burl :) :)
Dan,
I routinely use the first type of bit, but once I get in the ballpark....next to last pass is less than.002"..and final pass is .005" (usually) run twice.
Normally a minute ore two of 150G gets my surface uniform to work through the grits.
Is your spindle trammed? Get banged or run one of those "Oopsie" toolpaths that may have thrown it out of whack?
Just curious Dan.
GMH
scottp55
Postby Savannahdan » Tue Nov 12, 2019 12:47 pm
Scott, just a cheap bit that needing some sharpening/honing.
Savannahdan
Postby scottp55 » Thu Nov 14, 2019 3:32 pm
Figure I was preaching to the choir Dan!
Yep..have a few old 1.25" Whiteside Mortising bits like that :)
Still using them occasionally on roughing wet wood and bark cuts that may have some embedded mud while they were firewood....
Then when I get within .2" of where I figure I'll stop....swap over to a fresh/clean Whiteside for last little bit.
Wet wood quickly builds up junk on the cutter, and taking a minute to brass brush it with Bladecote makes a huge difference!
Even bits that Look clean...swiped with a fresh Viva paper towel have a thin coat usually after a few passes that increase sanding :)
Have a few people that regularly do slabs/tabletops and Love that bit for the reduction in sanding...although somewhere in the back of my mind, I remember in some circumstances they removed two of the cutters(?).
If all my stuff wasn't so small...I'd probably invest also:)
GMH
scottp55
Postby Savannahdan » Thu Nov 14, 2019 7:38 pm
I really need to get the carbide insert bit. I have quite a few slabs that need some attention before they re-root themselves and become trees again. The last piece I flattened was around 4"+, had sat protected for over 3 years and still had substantial movement after I cut it. Fortunately it was a piece that accepted the new "character" and folks love it. To be truthful, I have a large Woodhaven Planing Sled and Triton 3.25hp router which should be used for slabs.
Savannahdan
Postby Bill_L » Fri Nov 15, 2019 3:26 pm
Here is the bit that I use and it is made by Amana. Use it all the time with a pocketing routine and it does a great job:
https://www.toolstoday.com/v-13329-rc-2255.html
Bill_L
Users browsing this forum: Dan O and 22 guests
