Material Set-up Y Gap
Postby anyducks » Sun Nov 10, 2019 4:34 pm
In Material setup, the option "Rapid Z Gaps above material" sets the height the tool will move over the material .
I need to have Y move behind the work 1" when the current pass is completed.
When the current line is cut and the bit is returning for the next pass, it nicks the wood.
I can extend the line 2" and this reduces nicks. The 'Y' default seems to be .25 "
thanks
anyducks
Model of CNC Machine: 1 Shark HD
Re: Material Set-up Y Gap
Postby Adrian » Sun Nov 10, 2019 5:01 pm
There isn't such a thing as Y clearance during a cut (or X for that matter). You need to extend the vectors as you're doing. The "default" distance is basically the tool radius as the toolpath is calculated from the centre of the bit.
Postby anyducks » Sun Nov 10, 2019 10:56 pm
thank you
anyducks
Users browsing this forum: No registered users and 20 guests
