using resin
using resin
Postby Aussie » Fri Nov 01, 2019 1:42 am
Hi All,
My first time using resin..... the plan is to do a raised 3D carving in resin, I shall use form work to build the resin at 10mm above the timber base.
My question is coating the inside of the form work so the resin does not adhere to it...what do you use?
Ron
Aussie
Model of CNC Machine: Axiom AR6 Pro
Re: using resin
Postby highpockets » Fri Nov 01, 2019 1:52 am
Use a resin mold release agent
Re: using resin
Postby tomgardiner » Fri Nov 01, 2019 2:02 am
You can use plastic packing tape to line your moulds. Or do you call it cellotape?
tomgardiner
Re: using resin
Postby Aussie » Fri Nov 01, 2019 2:21 am
tomgardiner wrote:You can use plastic packing tape to line your moulds. Or do you call it cellotape?
thank you ...either one works for us
Aussie
Re: using resin
Postby nicksilva » Fri Nov 01, 2019 4:03 am
highpockets wrote:Use a resin mold release agent
I 2nd that. It's really just a spray polyurethane in most cases, but it will allow you to seperate the positive and negatives.
"Out of my mind. Back in 5 Minutes."
nicksilva
Model of CNC Machine: ULS M300, Rockler 60th Ann. Shark
Re: using resin
Postby wb9tpg » Fri Nov 01, 2019 1:27 pm
I use heavy duty packing tape and then coat it with Johnson Paste Wax
wb9tpg
Users browsing this forum: ezurick and 15 guests
