I've set up a toolpath template that should apply toolpathing based on the layer name imported from AutoCAD, but I'm having issues with it missing some of my vectors and I'm not sure what the cause is due to the seemingly random nature it chooses which ones not to toolpath. Specifically I'm trying to use a pocketing toolpath, and I've overlapped the pockets by 1/2 the diameter of the cutting diameter to be sure I'm not leaving a radius of uncut material in my pocket.
Here is what I'm trying to toolpath. The red lines are pockets, the blue lines are outside profile cuts. The green circles are 5MM holes.
Here is what it looks like when I calculate my toolpaths. You can see there are a few that were ignored.
Here is the actual VCarve file if anyone can help me figure this out I would greatly appreciate it.
