Ramp settings
Ramp settings
Postby paul60 » Thu Sep 19, 2019 8:54 pm
I have a large number of screens to cut enclosed sample file
what would be the recommended ramp setting to cut this file
trying to get away from the mark left by the plunge cut
using a .125 spiral down cutter thanks
sample.dxf
(779.23 KiB) Downloaded 29 times
paul60
Re: Ramp settings
Postby Rcnewcomb » Thu Sep 19, 2019 9:28 pm
I would use lead-in and lead-out and ramp on the lead-in.
I'd also recommend that you use the Curve-Fit tool to get rid of all the extra nodes before toolpathing and cutting the file.
Re: Ramp settings
Postby paul60 » Thu Sep 19, 2019 9:55 pm
Thanks Rcnewcomb what would be your recommended ramp settings for this file
Paul
paul60
Re: Ramp settings
Postby Rcnewcomb » Thu Sep 19, 2019 10:10 pm
It depends on the material thickness, but somewhere between 0.5" and 2 inches. Play around with circular vs. straight line too.
You may need to move the start node to the middle of a longer span to give it room.
Re: Ramp settings
Postby paul60 » Fri Sep 20, 2019 2:08 am
I am cutting half inch pvc board one pass .125 down spiral bit
paul60
Users browsing this forum: Barry Anderson, Gerald Martin and 28 guests
