V-10 Pdf Right Click Open With V.10 Not Visable
Postby signs 2 signs » Thu Sep 19, 2019 1:09 pm
V-10 Pdf Right Click Open With Vcarve V.10
im having trouble with Right click not working
Windows 7
Vcarve 8.5 Now uninstalled :(
signs 2 signs
Model of CNC Machine: AXYZ 4010 7G ATC , AXYZ 6010 7G ATC'
Re: V-10 Pdf Right Click Open With V.10 Not Visable
Postby Adrian » Thu Sep 19, 2019 1:45 pm
You have to use the "Other App" at the bottom of the right click menu before Windows will add it the list of programs that can open the file. There are many other ways of creating the association but that's the easiest.
With V10 the version number is now appended to VCarve so where it used to say VCarve in a menu like that it now says VCarve 10 so Windows treats it as a completely different program.
You can drag and drop PDF files into a VCarve session or open them directly from within VCarve as well as importing them.
Postby signs 2 signs » Thu Sep 19, 2019 3:31 pm
Yes i have done this Adrian and navigated to vc10 folder and it just opens with the default program thats selevted not vc10
Prior to uninstalling vc8.5 it give me both Choices
Maybe a Re installation ?
Also there is an issue with save as opening the last save location no the last open location so this can be a totally different location
Thanks Pete
signs 2 signs
Postby Adrian » Thu Sep 19, 2019 4:15 pm
PDF is not a default association for VCarve. Re-installing won't do anything as it's all to do with Windows. Prior to this release if you had two versions of VCarve installed (say V8 and V9) and you had set them up to open PDF's then you would have seen VCarve in the list twice with no idea which was V8 and which was V9. Now once you've set it up you should be seeing VCarve 10.
The default locations for Open and Save dialogs is now set via an option on the Options dialog in the Edit menu. You can have it set to Global (use last location), Job (use the location where the job was loaded), Operation (last used for that operation so you can have different locations for toolpaths and vector exports for example).
Users browsing this forum: rdean33422 and 27 guests
