Not cutting properly
Postby hbehning » Tue Sep 17, 2019 11:05 pm
After I go to calculate on profile toolpath, the passes are not on the same line so it is cutting off.
hbehning
Model of CNC Machine: Laguna Swift
Re: Not cutting properly
Postby dealguy11 » Wed Sep 18, 2019 12:24 am
Please post an example. Not clear what you're describing.
Steve Godding
dealguy11
Postby Adrian » Wed Sep 18, 2019 8:08 am
hbehning wrote:After I go to calculate on profile toolpath, the passes are not on the same line so it is cutting off.
Could be many things. Do you have open vectors in the selection? Depending on where the start node is the bit will cut one side or the other. You would need to move the start node or join the vectors depending on what you're trying to achieve.
The other possibility is that you don't understand the Inside/Outside/On settings in the toolpath. The Inside and Outside settings will cut with the edge of the bit on the line. The On setting will cut with the centre of the bit on the line.
If it's not any of those then, as has been said, you need to attach a file showing the issue.
Postby hbehning » Wed Sep 18, 2019 1:40 pm
I got it figured out thank you
hbehning
Postby ezurick » Wed Sep 18, 2019 1:53 pm
hbehning wrote:I got it figured out thank you
To be quite honest, these forums are here for our help and assistance. If you had an issue and got it resolved, then you should spend the few extra minutes explaining what the issue was and how it got resolved. We have many new users of the software, including myself and it might be something that we all may learn. It may not, but at least it would be better than "I have a problem... nevermind I fixed it".
ezurick
Postby nicksilva » Wed Sep 18, 2019 3:27 pm
my guess would also have been an open vector. I'm using the Vector Validator a lot more these days to solve problems.
Cheers!
"Out of my mind. Back in 5 Minutes."
nicksilva
Model of CNC Machine: ULS M300, Rockler 60th Ann. Shark
Users browsing this forum: FixitMike and 25 guests
