New one for today V-10
Postby Jan.vanderlinden » Fri Sep 20, 2019 5:13 pm
I am now getting a message that my job is too big.
Below are my job settings and the message that i get when I try to save the file.
I've learned so much from my mistakes, I'm thinking of making a few more.
Jan.vanderlinden
Model of CNC Machine: Xcarve
Re: NEW ONE TODAY FOR V-10
Postby highpockets » Fri Sep 20, 2019 5:18 pm
You have a Width of "FF"
Postby rscrawford » Fri Sep 20, 2019 5:37 pm
Are you using the desktop or the pro version? Desktop has a limited cut area.
Russell Crawford
rscrawford
Postby Jan.vanderlinden » Fri Sep 20, 2019 6:17 pm
John,
That is really crazy.
I just opened up the file again and these are the settings.
The file has to be corrupt somehow.
I just started a whole new one and there is no problem with it.
I use desktop and just upgraded to V-10
Jan.vanderlinden
Postby Leo » Fri Sep 20, 2019 6:23 pm
With the first one --- width FF - was likely a problem
www.leosworkshop.com
Leo
Postby Jan.vanderlinden » Fri Sep 20, 2019 7:54 pm
No, it still did it.
I just dumped the file and started over.
Jan.vanderlinden
Postby highpockets » Fri Sep 20, 2019 7:57 pm
I would suggest you send the file to support@vectric.com and let them have a look see.
Postby ezurick » Sat Sep 21, 2019 6:32 am
highpockets wrote:I would suggest you send the file to support@vectric.com and let them have a look see.
Right... another thing... when I ran into this issue. I also have the desktop size limitation. I was getting that error on a job although I know that the size was well under the 25 x 25. Here come to find out is that I was keeping extra vectors to the side (outside the wood area) and since they once had a toolpath, some hay the program didn't like that even though I was NOT using them in the current toolpath. As soon as I deleted those extra vectors it stop giving me the limitation error. I hope I explained that well enough...
~ Ed
ezurick
Re: New on for today V-10
Postby Jan.vanderlinden » Sat Sep 21, 2019 3:59 pm
That's interesting.
I also had vectors to either side of the work area.
Seems to me that something is wrong if the software is looking beyond the work area.
Come to think of it, I have done the same thing in V-9 and it wasn't a problem.
Jan.vanderlinden
Postby dealguy11 » Sat Sep 21, 2019 4:46 pm
I imagine since it's possible to machine vectors outside the work area using 2d toolpaths, that's why they're enforcing the size limitation. There are a number of reasons for giving people the ability to machine outside of the work area (for example, to preserve resolution for the 3d portion of the model), so it's not really an error.
dealguy11
Postby Adrian » Sat Sep 21, 2019 4:47 pm
It was the same in V9 as other people raised the "issue". If you have a vector off the work area that is part of the toolpath and it exceeds the desktop limit then you will get the error. I suppose it shouldn't really do that if it's not the active toolpath but that's the way it is as far as I'm aware.
The work area is only a visual reference. For many toolpaths there's nothing stop you defining the work area as an 1" square and then cutting to 25".
Postby mtylerfl » Sat Sep 21, 2019 5:56 pm
dealguy11 wrote:...There are a number of reasons for giving people the ability to machine outside of the work area (for example, to preserve resolution for the 3d portion of the model), ...
Hi Steve,
I’m not “getting” this particular example you mentioned. Would you mind explaining this a bit? The only application I can think of would be a model in a work area just big enough to contain it, then using job offsets (or offsets at the machine) to carve multiples. Is that what you mean?
carvebuddy.com
Return to VCarve - General
Users browsing this forum: Google [Bot] and 31 guests
