Warping problem
Warping problem
Postby Jan.vanderlinden » Tue Sep 17, 2019 10:19 pm
Looking for some advise.
Here is the problem.
Every time I carve a plaque, the wood warps as soon as I release the clamps from the machine bed.
I currently have a 3D plaque that I made that warped.
I set it up between two supports and put a 50lb. Weight on it for a couple of days.
It does in fact flatten back out, but after a few more days, it is warped again.
While I realize that when you cut something, you are also releasing stresses.
What do others on here do to either prevent it or straighten the project back out after carving?
Here is an example of one that I just cut yesterday.
I've learned so much from my mistakes, I'm thinking of making a few more.
Jan.vanderlinden
Model of CNC Machine: Xcarve
Re: Warping problem
Postby highpockets » Tue Sep 17, 2019 10:42 pm
Before carving the front carve a couple of slots in the backside and epoxy in steel rods.
Re: Warping problem
Postby dealguy11 » Wed Sep 18, 2019 12:27 am
Or just try hollowing out the back a bit before carving. It might even out the stresses and reduce the warping.
Steve Godding
dealguy11
Re: Warping problem
Postby TReischl » Wed Sep 18, 2019 12:40 am
Two things.
First if the carving itself is a dish shape then all you need to do is flip the piece over and flatten the back. Yes, the edges will vary a little bit but only us wood worker types study that sort of thing, everyone else just looks at the carving.
Second if the carving has a flat background you can still flatten the back side,
I do not do a lot of woody looking carvings so I like to glue up strips which really helps with this problem.
Re: Warping problem
Postby Jan.vanderlinden » Wed Sep 18, 2019 12:16 pm
Thank you for the feedback.
I've heard that red oak is notorious for warping.
And yes, I should maybe look at some glue up work.
Although, Highpockets has the best idea... :roll:
Jan.vanderlinden
Re: Warping problem
Postby Rcnewcomb » Wed Sep 18, 2019 3:42 pm
This thread from 10 years ago may be of interest: Warped Panel After Carving
Re: Warping problem
Postby adze_cnc » Wed Sep 18, 2019 4:41 pm
You could try using quarter-sawn wood instead of rift-sawn.
adze_cnc
Re: Warping problem
Postby Jan.vanderlinden » Fri Sep 20, 2019 8:21 pm
Excellent read Randy.
Thank you.
Jan.vanderlinden
Users browsing this forum: No registered users and 17 guests
