Countersink Gadget (Paul Rowntree) doesn't work in v10
Postby hdtom61 » Sun Sep 15, 2019 3:45 pm
Normally I use the Countersink Gadget from Paul Rowntree. It worked well under VCarve Pro 9.5. After the Update to v10 I can't use it: I'll get an error message.
How does other users realize countersinks with a normal endmill so that I don't have to change the tool when I want to mill a hole with a countersink at ist top end?
Regards
Thomas
hdtom61
Model of CNC Machine: Self built CNC milling machine
Re: Countersink Gadget (Paul Rowntree) doesn't work in v10
Postby Adrian » Sun Sep 15, 2019 3:58 pm
See here - viewtopic.php?p=70140#p70140
I expect Paul will update his gadgets soon though. Vectric updated their own gadgets and gadgets written by others (such as myself) that are on the "official" gadgets website but authors who host their own have to do their own updates to the new version.
Postby hdtom61 » Sun Sep 15, 2019 5:34 pm
Thank You for the link and your Information ;-)
hdtom61
Postby Janus » Fri Sep 20, 2019 8:28 am
Is there any information from Vectric about what exactly has been changed in the gadgets?
Maybe you can correct the programs yourself.
Jan
Janus
Postby hdtom61 » Sun Sep 29, 2019 12:54 pm
In the meantime I wrote a message belonging this Problem to Paul Rowntree a few days ago. But till today I've got no answer from him. I'll Keep you informed here, if I'll get answer from Paul.
I've no Information from Vectric about the changings concerning the Gadgets.
Regards
Thomas
hdtom61
Postby AdamJ » Sun Sep 29, 2019 9:20 pm
Hi All,
That gadget is a paid for one from Paul, and even it were free then I'm not sure we would have the right to make changes to the code he has generously provided and distribute it ourselves.
Having no access to the code means that this one is hard to debug, however the major breaking change for version 10 gadgets was that the tool database structure changed and the method that sets a default tool got broken. In our own gadgets we had a lot of code that looked like this:
Code: Select all
dialog:AddToolPicker("ToolChooseButton", "ToolNameField", options.default_toolname)
and changing it to something like this
Code: Select all
   dialog:AddToolPicker("ToolChooseButton", "ToolNameField", ToolDBId())
got it working again, if not exactly correctly. Just to be clear the key bit to search for is AddToolPicker, and the third argument getting changed is the main thing - it used to used to accept the name of a tool but now it needs a tool ID.
Hopefully this helps, but unfortunately the circumstances mean we can't be much more helpful.
Adam
AdamJ
Model of CNC Machine: None
Postby hdtom61 » Fri Oct 11, 2019 4:04 pm
Adam: Thank you for your help. but I'm not a Spezialist for coding.
In the meantime I've tried to contact Paul Rowtree by mail several times. Unfortunately I got no answer from him. So I think he isn't interested to update his Gadgets for the future.
Maybe in future update Vectric can add a function directly into Vcarve and Aspire, that we can realize countersinks with a normal endmill and we save at least one tool changing.
I think there are many users who are waiting for such a toolpath ;-)
Regards
Thomas
hdtom61
Users browsing this forum: greggph, kaetamer, Phil and 10 guests
